[GRASS5] Driver Update
Glynn Clements glynn.clements at virgin.net
Thu Apr 26 11:35:04 EDT 2001
Justin Hickey wrote:
> > from the client. Can you add a "if (n_read == 0) printf(...)" to
> > read1() just to confirm this beyond doubt?
> Yes, n_read == 0.
> > If so, it looks like the problem is in the client after all.
> > Also, could you try swapping in the old version of
> > src/libes/raster/io.c [1] to see if that works?
> > [1] cvs update -r devices_cleanup_20000420 src/libes/raster/io.c
> This is the fifo version. Where is the socket version?
Duh; should be
cvs update -r devices_cleanup_20000420 src/libes/raster/socket.new/io.c
then move the file into place.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
