[GRASS5] Cleaning and merging v.in.dxf, v.in.dxf2
Michel Wurtz mw at teledetection.fr
Fri Apr 20 02:32:06 EDT 2001
David D Gray wrote:
> I suggest v.in/out.mif as v.in/out.mapinfo is ambiguous and we might
> want to reserve it for possible use in importing binary mapinfo in
> future.
I agree with you. BTW, all import export program use the same
naming convention : v.in.xxx or v.out.xxx with xxx = e00, mif, dxf, ...
at the exception of shape (should we call them v.in.shp and
v.out.shp instead of v.in.shape and v.out.shape ?)
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
