[GRASS5] Re: Current GDAL problem
Bob Covill bcovill at tekmap.ns.ca
Tue Apr 17 11:10:02 EDT 2001
mberglund wrote:
> On Tue, 17 Apr 2001, Markus Neteler wrote:
> > Mhhh, this is also surprising. How did you start nviz?
> Tcktkgrass and grass commandline.
> > Perhaps try:
> > nviz2.2 el=yourelmap
> >            ^^^^^^^^^ use some correct raster map name
> > does this work?
> Nope.
> Later,
> Matt
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Hello,
Try starting NVIZ in "quck start" mode with:
nviz -q
With this switch no data will be loaded and nviz will simply start. Data
can be loaded from the menu after the viewer is open.
You should also make sure that the Current GRASS region is set to the
raster you are loading. If the raster is outside the Current GRASS
region it can cause problems.
Hope this helps.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
