[GRASS5] Compilation on HP-UX
Robert Lagacé lagace at echo.grr.ulaval.ca
Mon Apr 16 18:08:52 EDT 2001
Finally I found time to try compile GRASS on HP-UX.
I download the last snapshut of GRASS and proceeded
to compile it.  So, I run ./configure and got somme
checking with negative results.  I want to know if they
may cause problems.
checking for flex... lex
??? the REQUIREMENT files say flex no lex is suported.
??? flex is available for HP-UX
Are they any problems with thoses ?
checking for bison... no
checking for byacc... no
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for seteuid... no
checking for initscr in -lncurses... no
checking for initscr in -lcurses... yes
checking for xdrmem_create in -lsun... no
checking for xdrmem_create in -lnsl... no
checking for xdrmem_create in -lrpclib... no
checking for atan in -lc... no
checking for atan in -lm... yes
checking for dlsym in -ldl... no
I have some missing libraries that are easy to correct.
Thanks.
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
