[GRASS5] XDRIVER
Markus Neteler neteler at geog.uni-hannover.de
Tue Apr 10 03:28:39 EDT 2001
On Mon, Apr 09, 2001 at 08:36:58PM +0100, Glynn Clements wrote:
> I'd like to suggest integrating the new XDRIVER code into the source
> tree.
> The current mechanism of having "configure" modify several files
> (which are under CVS control) suffers from a couple of problems:
> 1. Running "cvs diff" includes the differences between the *.new
> versions of the files and the CVS versions. This is a bit of a
> nuisance if you're doing general tidying (minor changes to many
> scattered files), where it's simpler to diff the whole tree than to
> figure out exactly which files need to be diff'd.
> 2. Anyone running "cvs commit" without thinking will overwrite the CVS
> versions (fifo?) with whichever version is in their build tree at the
> time (probably sockets).
> If I hadn't encountered (1) first, I probably would have encountered
> (2) instead.
Hi all,
I agree with Glynn. Perhaps we only keep the fifo version in a
subdirectory along with the established mechanism to activate it
(Bernhard wants to keep fifos for old platforms) and put the
sockets version into the default place. I guess that 99% of users
want sockets.
Any objections?
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
