[GRASS5] Status of 5.0.0 release
Glynn Clements glynn.clements at virgin.net
Mon Apr 9 10:50:04 EDT 2001
Markus Neteler wrote:
> > > as it becomes rather siltent in CVS, I suggest to release
> > > GRASS 5.0.0 *now*.
> > > We have three RC tagged bugs left in BUGS and a few in
> > > RT-service. However, I don't see that they get fixed in
> > > reasonable time.
> > Is [bug #229] applicable to the release candidate? (I'm using the
> > bleeding-edge version, so I don't know).
> > If it is, it should be fixed (I can provide a patch if necessary). If
> > developers haven't been bitten by this, maybe it's because they have
> > write permission on their PERMANENT mapset(s). End users are more
> > likely to be bitten by it.
> Hi Glynn,
> thanks for fixing it (I assume it was #229 as RT is still down).
Yes, it was #229.
BTW, I have the CVS "head" checked out, not the release branch; I
don't know if or how this affects the release (I've never managed to
get to grips with CVS branches; I'm still not quite sure whether I
really understand how non-branch tags work).
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
