[GRASS5] TODOs for 5.0.0
Bernhard Reiter bernhard at intevation.de
Thu Aug 9 08:34:05 EDT 2001
On Thu, Aug 09, 2001 at 12:56:43PM +0100, Glynn Clements wrote:
> Conclusions:
> If non-GPL code must be removed for the 5.0.0 release, and time is
> pressing, I suggest simply removing the offending code, and either
> removing dependent programs, or disabling them in src/CMD/lists/GRASS.
> I suspect that failure to work altogether is more likely to result in
> a program being fixed than failure to comply with the GPL.
A completly agree that we have to remove the code then.
Disabling will collide with the GPL.
> I'll work on egvorder/egvorder2 and rand1 initially.
> I'm willing to work on fft/del2g and jacobi if someone can provide me
> with test cases (test data and usage instructions) which exercise the
> functions in question.
Thanks for helping.
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010809/6fbcadd0/attachment.bin
