[GRASS5] WARNING: CVS broken
Bernhard Reiter bernhard at intevation.de
Fri Aug 10 03:56:23 EDT 2001
On Thu, Aug 09, 2001 at 11:31:54PM +0100, Glynn Clements wrote:
> Roger Miller wrote:
> > > I just tried a "cvs update", and it very much looks as if the CVS
> > > repository has suffered a botched merge attempt. I *really* hope that
> > > someone has a backup.
> > If there are no better solutions then I have the the entire tagged release
> > that I downloaded and updated about 4 1/2 hours ago. I've made no changes.
> I meant a backup of the repository itself; I reverted my local copy
> with "cvs update -r ... -D ...".
> But the repository itself would ideally be restored to the state it
> was in before the snafu. Otherwise there's going to be a pretty
> massive artifact in the revision history. Unfortunately CVS doesn't
> have a "rollback" command.
As Jan pointed out we do have a backup.
On the other hand we should try to work out the problems
using CVS first before trying the backup (IMO).
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010810/f463f846/attachment.bin
