[GRASS5] Re: NVIZ crashes
Markus Neteler neteler at itc.it
Mon Aug 13 10:19:36 EDT 2001
Hi all NVIZ lovers,
an update on Redhat7.1/Nviz crashes:
It seems to be related to Xfree86. I have a Matrox G450 card
running and Xfree 4.0.3 with DRI activated (= nviz crashes
the server).
After disabling DRI (direct rendering) it works fine...
In case of this problems, check your /etc/X11/XF86Config-4
and disable
#       Load "dri"
#       Load  "glx"
restart the Xserver and try agin NVIZ.
But... starting
 nviz dem
and
 nviz -q dem
leads to different values for zexxag...
Anyway, NVIZ seems to work again.
Markus
