[GRASS5] WARNING: CVS broken
Bernhard Reiter bernhard at intevation.de
Mon Aug 13 20:23:22 EDT 2001
> AFAICT, this is consistent with someone adding a non-branch
> releasebranch_11_april_2001_5_0_0 tag to all of the files at the head.
> Now, clearly CVS shouldn't have allowed this to happen, but it did,
If it is a bug, maybe we have to look into a newer cvs server version
to upgrade to...
> and I'm doubtful that it can actually be undone without restoring from
> a backup (which is problematic because people have been continuing to
> commit changes).
It might be possible if the change can be made easily on the ,v
file in the repository itself.
> However, I'm currently executing
> 	cvs tag -b releasebranch_14_august_2001_5_0_0
> on what I think is a correct copy of the release branch, i.e. the one
> I had before the problem occurred, with the subsequent commits (listed
> in the ChangeLog) added.
> If this works, people should be able to get a working copy of the
> release branch with:
> 	cvs update -r releasebranch_14_august_2001_5_0_0
Thanks for making progress.
I appologise for not having enough time to look into the issue right now.
	Bernhard
Professional Service around Free Software                (intevation.net)
The FreeGIS Project                                         (freegis.org)
Association for a Free Informational Infrastructure            (ffii.org)
FSF Europe                                            	  (fsfeurope.org)
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010814/eadabe1e/attachment.bin
