CVS analysis (Re: [GRASS5] Time to go mad: CVS completely messed up?!)
Glynn Clements glynn.clements at virgin.net
Tue Aug 14 15:53:16 EDT 2001
Bernhard Reiter wrote:
> > Now I will dig into the history command options to find out
> > what actions caused this behaviour.
> The history does not contain enough information to find out
> what has happened when.
> I found out, though that there might be a way to find all files within
> the repository which are on a non-branch "releasebranch_11_april_2001_5_0_0"
> tag.
If so, that's the difficult part solved.
> Removing the line with the tag in the repository file might then cure
> the problem.
> Glynn: I removed the d.rgb/cmd/main.c again after checking out the
> releasebranch_11_april_2001_5_0_0 version and it looks like this
> just removed the Revision tag.
That appears to work.
Glynn Clements <glynn.clements at virgin.net>
