[GRASS5] NVIZ: DRI acceleration running!
Helena Mitasova hmitaso at unity.ncsu.edu
Wed Aug 22 11:50:45 EDT 2001
Markus
is there a chance that this will fix our NVIDIA problem?
(what was the tkInt doing?)
thanks,
Helena
Neteler wrote:
> Hi there,
> good news: the DRI acceleration is working now (at least here,
> tested on different machines). Congrats to Roberto Flor.
> The fix is in CVS, if you want to test:
>  cvs up -dP src.contrib/GMSL/NVIZ2.2
>  gmake5 -i src.contrib/GMSL/NVIZ2.2
> Roberto has upgraded the togl.c to 1.5 (which was already living in
> GMSL/NVIZ2.2/TOGL for amusement). The real fix was that the wrong
> tkInt was included (fixed now). Even the original TOGL packages
> contain this bug...
> So - don't forget to activate DRI in /etc/X11/XF98config[-4].
> The "gears" program or "glxinfo" will tell you about DRI running.
> NVIZ is really FAST now.
> Thanks to Roberto Flor from ITC-irst,
>  Markus
> On Wed, Aug 22, 2001 at 04:26:59PM +0200, grass at intevation.de wrote:
> > Date: Wednesday August 22, 2001 @ 14:26
> > Author:       markus
> > Update of /grassrepository/grass/src.contrib/GMSL/NVIZ2.2/src
> > In directory doto:/tmp/cvs-serv5174
> > Modified Files:
> >       Tag: releasebranch_11_april_2001_5_0_0
> >       togl.c togl.h
> > Added Files:
> >       tkInt.h tkInt4.0.h tkInt4.1.h tkInt4.2.h tkInt8.0p2.h
> >       tkWinInt.h
> > Log Message:
> > Roberto Flor <flor at itc.it>: upgraded to TOGL 1.5, fixed NVIZ crash with
> > DRI and Xfree 4.0.3/4.1.0 by using the right tkInt file (wrong version was
> > included)
> > grass-commit mailing list
> > grass-commit at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass-commit
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
