[GRASS5] d.leg.thin is now d.legend
Glynn Clements glynn.clements at virgin.net
Tue Dec 18 15:39:29 EST 2001
Markus Neteler wrote:
> as functionality is identical (no, better), d.leg.thin is now d.legend.
> I have removed the old d.legend and updated the html pages.
Someone needs to either:
a) update src/tcltkgrass/module/d.legend to match the new syntax, or
b) change d.legend to use the old syntax.
a) is less work; b) is backwards compatible with users' experience,
and any scripts which they may have.
Glynn Clements <glynn.clements at virgin.net>
