[GRASS5] Known Solaris 7 issues with beta 11]
Bob Covill bcovill at tekmap.ns.ca
Thu Feb 22 08:09:27 EST 2001
"Eric G. Miller" wrote:
> On Wed, Feb 21, 2001 at 12:11:37PM -0400, Bob Covill wrote:
> > - I had trouble with the unix_sock.c in libes/gis with PF_LOCAL not
> > recognized by the version of solaris sockets installed. Eric has since
> > corrected this problem.
> I was not aware of this separate socket library (it is part of libc
> here).
> > - The sockets lib was not getting included (-lsocket) in the build. It
> > was defined under CMD/head/head.arch with the flag "XEXTRALIBS" however
> > this was not being picked up by the necessary build. I added a
> > "-lsocket" to XDRLIB which corrcted the problem.
> That would do it..
> > - NVIZ failed to install because it claimed there were no TK TCL libs.
> > When I examined the head.arch file the TCLTKLIBS line was empty. I added
> > -ltk and -ltcl and NVIZ built cleanly.
> What, no version numbers?  At least the inconsistency is consistent...
> Linux => -ltk8.? -ltcl8.?
> CygWin => -ltk8? -ltcl8?
> Solaris => -ltk -ltcl
> Was configure able to find the headers?
> Eric G. Miller <egm2 at jps.net>
Eric,
Configure did pick up the headers and the lib directory, only the actual libs
line was empty. It should have picked  up 8.0 for the version number.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, NS
Canada
B2T 1K6
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
