[GRASS5] GRASS 5 and sockets: default?, NVIZ fixed
Helena hmitaso at unity.ncsu.edu
Mon Feb 19 10:09:30 EST 2001
>What about the NVIZ troubles? I cannot reproduce Helena's problems.
Markus, Bill tested the latest version of NVIZ from CVS with my data
and state files and he says that it works OK (it is more "contrasty" than it
used to be but it renders the surface completely). He has also tested
the upgrading of floating point rasters to the new compression:
>I also wrote a script to make the floating point map conversion easier,
>r.upgrade
>So if you want to convert all your fp maps for a mapset, just go to
>$LOCATION/fcell and type "r.upgrade *"
so that seems to be OK too.
g3d definitely has to go into 5.1 - there is too much work to do to make it
really useful at this point.
Were you able to fix all the installation and compilation problems that were
in beta10-11? Those are the most important to get fixed for the release.
Helena
Markus Neteler wrote:
> Hi all,
> the sockets driver is maturing quickly. Question is if
> we should make it default for the forthcoming 5.0.0
> or not.
>  - we need a platform report about it's quality
>      o Linux: running well (better than fifos)
>      o SGI:
>      o Windows/Cygnus:
>      o FreeBSD:
>      o Solaris2.6/SUN: running well (better than fifos)
>      o Solaris8/SUN:
>      o Solaris/Intel:
>  - what's missing (hi Eric)
>         - locks directory moved to $HOME/.grass5/ (?)
>  - what's to be postponed to 5.1:
>         - scale in top line of monitor (?)
>         - auto-redraw when resizing  (?)
> I have the impression that the sockets driver is the last thing
> missing for 5.0.0 (stable) except the few release-critical bugs in BUGS.
> We won't be able to get G3D stable, so that will be postponed to
> GRASS 5.1 (and left out of 5.0.0).
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
