[GRASS5] Re: dev/fifo's
Markus Neteler neteler at geog.uni-hannover.de
Fri Feb 16 10:14:24 EST 2001
On Fri, Feb 16, 2001 at 03:29:53PM +0100, Edzer J. Pebesma wrote:
> I just installed the `latest' grass beta, from sources on a linux
> redhat 6.2 box. It compiled and installed fine, but the fifo's in
> /usr/local/grass5/dev were not created. Instead, I found a shell
> script with that name that tried to write files in a directory
> with it's own (shell script) name!
> Below is a shell script that made it work. Note that I removed a few
> tests (around the former touch, now mkfifo commands).
> Best regards, and my compliments for the work,
> Edzer
Hi all,
it seems the source ball still contains the bug. Shall we
tag and release beta12 (oh my dear, this inflation of versions...)?
People could enjoy the optional sockets then.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
