[GRASS5] Grass5 on Solaris
Bob Covill bcovill at tekmap.ns.ca
Thu Feb 15 12:44:01 EST 2001
Markus Neteler wrote:
> > > On Thu, Feb 15, 2001 at 11:32:06AM -0400, Bob Covill wrote:
> > > > Hello,
> > > > I am trying to build the latest GRASS on my Solaris machine. The version
> > > > is up to date from the CVS yesterday (feb. 14).
> > > > The problem I am having is the GIS lib is not getting built, which is of
> > > > course rather important. The GIS lib is failing with file flate.c at
> > > > line 120. The comments in the file indicate that this will fail if ZLIB
> > > > is not installed. The libz is installed in  /usr/local/bin.
> > > > Any thoughts on what I am doing wrong? It sucessfully built on Linux
> > > > without problem.
> Probably I know the problem! The configure should set:
> HAVE_ZLIB_H
> in src/include/config.h
> Maybe this wasn't successful? The flate.c has a test:
> #ifndef HAVE_ZLIB_H
> static void
> break_compile (void)
>     /* if ZLIB is not installed, a compile error is generated here */
>     NULL = 1;
> So the compiler will break if HAVE_ZLIB_H is not set.
> Check the src/include/config.h.
> Regards
>  Markus
Markus,
You were close. It appears that flate.c was using the wrong config.h header. It was
reading one from /usr/local/include, and therefore not getting any defines. If I
manaully add the define HAVE_ZLIB_H to flate.c or add the full path to config.h it
compiles cleanly.
The problem should be solvable by ensuring that the first "-I" flag looks in
grass/src/include instead of picking other config.h files.
Bob Covill
Tekmap Consulting
P.O. Box 2016
Fall River, NS
Canada
B2T 1K6
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
