[GRASS5] zlib
Markus Neteler neteler at geog.uni-hannover.de
Mon Feb 12 17:38:44 EST 2001
On Mon, Feb 12, 2001 at 03:14:26PM -0600, B. Byars wrote:
> Thanks Eric,
> Yep that will get configure running (what I had to use), BUT there's
> still big-time solaris problems.  Can;t "do-compile", setting directory
> paths in configure are ignored, can't make binaries.  Like I say, I can
> hard-wire things to get them to work, but configure as it is on solaris
> 7 32-bit is awful in beta 11.
> Shall keep you posted on fixes.
Hi Bruce,
currently the compile is running here on Solaris2.6 /SUN - luckily
without problems. I will test the new XDRIVER/sockets tomorrow when
compile is finished.
It seems to be a solaris7 problem. It would be helpful if you post
the errors, maybe they can be fixed easily.
Thanks,
 Markus
> "Eric G . Miller" wrote:
> > On Fri, Feb 09, 2001 at 04:18:56PM -0600, B. Byars wrote:
> > > Solaris 7 32 bit has trouble finding zlib's located in
> > > /usr/local/.  I've had to hard wire this to get a compile
> > > to go.  Any quick fixes already or should I dig deeper?
> > ./configure --help
> > Let me know if it doesn't work (--with-zlib-<includes|libs>=[dir]).
> > Eric G. Miller <egm2 at jps.net>
> > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > minordomo at geog.uni-hannover.de with
> > subject 'unsubscribe grass5'
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
