[GRASS5] G_sock_*, XDRIVER, and other fun...
Markus Neteler neteler at geog.uni-hannover.de
Mon Feb 12 06:48:41 EST 2001
Hi Eric,
here my report on XDRIVER/sockets:
o it works o.k.! And, hey, you can simply click-off the monitor...
  This is definitly a useful improvement.
o the monitor comes up much faster
o the refresh problem with hidden monitor is still there (KDE2,
  you will know it).
Small idea to improve:
If you click-off a monitor and run d.rast (or whatever) later, you get:
  d.rast tk25
  Socket is already in use or not accepting connections.
This message might be extended: "Run d.mon to start new monitor.".
A problem is, that the message doesn't time-out. Means, you need to Ctrl-C
it away (funny: you have to hit return, before Ctrl-C is accepted).
Could you use G_fatal_error() for this message?
Eric, congratulations to you quick implementation of sockets. It offers
long awaited features.
regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
