[GRASS5] Identify GRASS database directory
Justin Hickey jhickey at hpcc.nectec.or.th
Thu Feb 8 23:33:30 EST 2001
Hi Bernhard
"B. Byars" wrote:
> > If you already have some script, it would be great if you are
> > willing to share it.  Mail it to me or make it overwise available.
> Hi Bernhard,
> I'll email you my scripts in just a bit.  Do look at Justin's
> scripts in tcltk as Markus suggests as well.
What I do in the startup script is check if PERMANENT is a mapset of the
given location. As Bruce stated, there is no real guarantee that
PERMANENT will be a mapset in all locations, but I have also seen
mapsets without a WIND file as well. In short, to the best of my
knowledge, there is no way to guarantee a particular directory belongs
to Grass. The reason I picked the check for PERMANENT was because some
Grass modules will report an error if a location does not contain a
PERMANENT mapset. At least I remember getting that error a few times in
the past.
However, I plan to change this in the new initialization code I am
working on. I not only plan to add a check for a PERMANENT mapset in the
current location when you start Grass, I also plan to put in a Create
Location feature that will always create a PERMANENT mapset as part of
the creation process. Thus, checking for a PERMANENT mapset will be a
reliable way to test for Grass databases starting with Grass 5.1 (I
hope).
If you're interested in looking at the code it is in
src/tcltkgrass/main/gis_set.tcl in the procedure CheckLocation around
line 220.
Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
