[GRASS5] Identify GRASS database directory
B. Byars Bruce_Byars at baylor.edu
Wed Feb 7 13:03:29 EST 2001
Hi Bernhard,
The PERMANENT directory isn't automatically created each time
with a new mapset.  Not sure what you mean about finding out is
a directory is a GRASS dbase directory tho'?  I have a script I use to
locate directories that looks for WIND files.  Is that what you mean?
Bruce
Bernhard Reiter wrote:
> Just a quick question. Is there a fast and relyable way to find out,
> if a directory is a GRASS database directory?
> I expect the PERMANENT mapset directory to actually be created
> once a directory serves as a GRASS database. Is this true for all
> cases?
> Thanks,
>         Bernhard
> Professional Service around Free Software                (intevation.net)
> The FreeGIS Project                                         (freegis.org)
> Association for a Free Informational Infrastructure            (ffii.org)
> FSF Europe                                                (fsfeurope.org)
>    Part 1.2Type: application/pgp-signature
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
