[GRASS5] Todo
Markus Neteler neteler at geog.uni-hannover.de
Sun Feb 4 09:42:39 EST 2001
On Sun, Feb 04, 2001 at 06:14:55AM -0700, John Huddleston wrote:
> Grass list,
> I checked out the code yesterday (not an update, a cvs co)
> and it failed because it could not change directory into a TODO
> directory.   In Unix we can have upper and lower case
> distinctions, not so in Cygwin.  Would somebody please
> check to see if there is a "todo" directory, if so, remove
> the todo file?
Hi John,
yes, I can see the problem (bad Windows!). So I will rename
todo/ to src.todo.
Sorry for this inconvenience,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
