[GRASS5] Re: [GRASS-COMMIT-CVS] CVS update: grass/src/scripts/shells
Jan-Oliver Wagner jan at intevation.de
Tue Jan 30 01:31:06 EST 2001
On Tue, Jan 30, 2001 at 02:59:44PM +0900, GRASS wrote:
> Hmm... "cvs remove" did not move RCS file into Attic. So i cannot readd
> this file.. :-(..
with cvs command "remove" you are scheduling a file for removal.
after that you need to delete the file in your own cvs tree ("rm")
and finally commit the file.
Pretty good mechanism against unintented removal :-)
Jan
Jan-Oliver Wagner               http://intevation.de/~jan/
Intevation GmbH	              	     http://intevation.de/
FreeGIS	                               http://freegis.org/
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
