[GRASS5] Mac OS X errors
Jeshua Lacock jeshua at SierraMaps.com
Tue Jan 30 00:49:42 EST 2001
On Monday, January 29, 2001, at 09:20 PM, Malcolm Blue wrote:
> Yes, the change to Makefile did the trick.  After I renamed INSTALL.doc back to
> INSTALL, I got the error that Justin reported with 'make install'.  When I made
> the changes you suggested in Makefile, grass was (re)installed. i.e. it did not
> report "`install' is up to date" and stop.
Guys,
Works for me too.
I am surprised that it is not case sensitive.  The shell I use is.
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
