[GRASS5] Mac OS X errors
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Jan 29 21:49:21 EST 2001
Hi Jeshua
Jeshua Lacock wrote:
> On Monday, January 29, 2001, at 05:54 PM, Justin Hickey wrote:
> > > It says: "make: `install' is up to date." and it does nothing
> > > other then return the command prompt.  It doesn't hang or
> > > apparently do anything.
> > Hmmm. Is there a file in the same directory called "install"? If so
> > please rename it and then "make install" should work. If not, I know
> > there is a file called "install-sh", try renaming that file.
> Justin,
> There is not an install file, so I moved the install-sh and its the
> same.  Sorry for the headaches...
Don't worry about the headaches, the more portable we get this the
better.
The only way I know for you to be getting the "make install: is already
up to date" message is that make is finding a file called install
somewhere. Don't worry about it, there are ways around this (I hope).
Try putting the following in your Makefile:
replace the line
install:
with the lines
FORCE:
install: FORCE
and let me know if "make install" works.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
