[GRASS5] Mac OS X errors
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Jan 29 01:59:12 EST 2001
Hi Jeshua
Jeshua Lacock wrote:
> Note that I had to issue a "make real-install" for it to install;
> "make install" seemed to do nothing.
Very strange - especially since "make" seems to work for you. Was there
any output when you tried "make install"? Or did it just seem to hang?
What happens if you remove the "@" sign before the if statement below
(the one above the ^ symbol)?
install:
   @ # The following action MUST be a single action. That is, all lines
   @ # except the last line must have a backslash (\) at the end to
   @ # continue the statement. The reason for this is that Make does not
   @ # have an exit command thus, exit terminates the shell. However,
   @ # Make creates a new shell for each action listed for a target.
   @ # Therefore, the only way exit will quit Make is if there is only
   @ # a single action for the target.
   @ # Check if grass has been compiled, if INST_DIR is writable, and if
   @ # grass is part of INST_DIR
   @ if [ ! -f ${GRASS_BIN}/grass${NAME_VER} ] ; then \
   ^   echo "ERROR: Grass has not been compiled. Try \"make\" first."; \
       echo "  Installation aborted, exiting Make."; \
Is anything printed out if you try "make install" now? Finally if you
still don't see anything, then please send me your copy of your Makefile
(not Makefile.in).
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
