[GRASS5] r.lzw2z updated...
Eric G . Miller egm2 at jps.net
Mon Jan 22 05:35:34 EST 2001
On Mon, Jan 22, 2001 at 09:36:25AM +0000, Markus Neteler wrote:
> Eric,
> just tested the updated module:
>  - no segfault any more, but
>  - I get this warning:
>    Processing aspect at helge ... Copying ... WARNING:
>    cell_misc/aspect/f_format file may be corrupted!
>    Processing slope at helge ... Copying ... WARNING: cell_misc/slope/f_format
> There seems to be one bug left.
Could you check what one of these files looks like?  Maybe I need to
handle a return value differently...  Following conversion it should
look like...
type: float
byte_order: xdr
lzw_compression_bits: -1
Prior to conversion, lzw_compression_bits should be between 9 and 20.
If it failed to update/write the file, the warning is correct.  However,
we don't want it to fail ;)
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
