[GRASS5] bugs
Markus Neteler neteler at geog.uni-hannover.de
Thu Jan 18 09:55:23 EST 2001
Hi there,
On Wed, Jan 17, 2001 at 10:59:50PM -0800, Eric G . Miller wrote:
> On Wed, Jan 17, 2001 at 10:40:38PM -0600, Helena Mitasova - staff wrote:
> [snip]
> > I too think that beta11 should be released ASAP and that
> > the LZW should be removed now - it will be too late to
> > do it after beta11, I am worried about it because i have
> > about million FP raster files, but it really needs to be done and
> > tested.
I fully agree to switch off LZW NOW!
If o.k., I'll do it in one hour.
> Helena, I have a GRASS module that will perform the translation from LZW
> to LIBZ compression for floating point rasters an entire mapset at a
> time.  It tries to be paranoid about making sure it can read what it
> writes; so, the data is read/decoded/recoded to a temp file, then reread
> and if successful transferred back to the original.  It seems to work
> okay (but has had little testing) -- http://www.jps.net/egm2/r.lzw2z.tgz
Helena, I have tested it, it is o.k.
> It's meant entirely for those situations where a copy of an earlier
> version of GRASS is not readily available.  Haven't worked out how to
> distribute it, since it contains the offending LZW code.
Question is if we shall integrate it into GRASS or not for the users.
> (A shell script to run "r.compress -u" using earlier version of GRASS
> before upgrading might be a little safer).
I have already written such script and the announcement:
http://www.geog.uni-hannover.de/grass/announces/announce_lzw_removal.html
-> fp_uncompress.sh: uncompress all raster maps. Save and run within your
   old GRASS 5
-> fp_recompress.sh: recompress all raster maps with DEFLATE. Save and run
   within new GRASS 5
It runs r.compress.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
