[GRASS5] More notes on BUGS list...
Eric G . Miller egm2 at jps.net
Sat Jan 13 02:01:33 EST 2001
Going through BUGS list again...
d.param.scale:
  Removed?  Related to removal of optri?
d.rast.edit:
  Seems to edit floating point just fine.
d.sites.qual:
  Can we get some decision about whether this is or isn't a BUG.
  (I vote that it isn't).
g.select.pg:
  Think I fixed all that a few weeks back...
i.tape.tm.fast:
  Think it's fixed, but I can't really test without tape drive and TM
  imagery.  It get's past segfault in interactive...
r.in.hdf/r.out.hdf:
  I didn't see anything in the hdf dirs indicating any version for hdf5.
  I'd recommend not including the HDF5 library with GRASS sources should
  such a thing ever come to be.  Such a thing should just use the shared
  library (if present, else no compile).
r.los:
  Should we just have it exit for lat/lon rasters/databases?  I'm not
  sure how to handle the metrics (what would the elevation units be?).
r.null:
  I still think the behavior about reclass maps is right.
r.out.tiff:
  The -t flag problem should be fixed now.  The NULL color thing is
  kind of fixed.  This module really needs a ground up rewrite.
r.rescale:
  Agree with Andreas on Zero vs. NULL thing.
That's enough for now ;)
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
