[GRASS5] Severe (simple to fix?) problem with current GRASS
spijker at geo.uu.nl spijker at geo.uu.nl
Thu Jan 11 04:22:33 EST 2001
On Thu, 11 Jan 2001, Justin Hickey wrote:
[front.end fix]
> A fix is on the way soon. I just hope it works.
A tempory and simple solution can be creating symbolic links in the
/usr/local/grass5/etc/bin directory from the contrib, main and alpha dir
to the current dir. In my case:
spijker at spijker:bin$ pwd
spijker at spijker:bin$ ls -al
total 20
drwxr-sr-x    4 spijker  src          4096 Jan 10 16:55 .
drwxr-sr-x   18 spijker  src          4096 Jan 10 16:55 ..
lrwxrwxrwx    1 spijker  src             1 Jan 10 16:55 alpha -> .
drwxr-sr-x    2 spijker  src          8192 Jan 10 16:51 cmd
lrwxrwxrwx    1 spijker  src             1 Jan 10 16:55 contrib -> .
drwxr-sr-x    2 spijker  src          4096 Jan 10 16:50 inter
lrwxrwxrwx    1 spijker  src             1 Jan 10 16:55 main -> .
It works fine
Grtz, Job
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
