[GRASS5] configure-problem on linux and irix
Eric G . Miller egm2 at jps.net
Mon Jan 8 04:01:08 EST 2001
On Mon, Jan 08, 2001 at 02:23:17PM +0700, Justin Hickey wrote:
> Hi Eric and Andreas
> "Eric G . Miller" wrote:
> > > checking TIFF include dirs...  -I/usr/freeware/include
> > > checking additional TIFF library dirs...  -L/usr/freeware/lib32
> > > checking for TIFFOpen in -ltiff... yes
> > > checking Tcl include dirs...  -I/usr/freeware/include
> > > ./configure[3404]: test: argument expected
> > I looked, but couldn't find anything.  I don't see that error here,
> > even when I specify --with-tcltk-includes=/usr/include/tcl8.3.  All
> > the "test" calls have arguments (though some, of course, may have
> > empty values).
> I found what is causing the problem. The line it refers to is
> if test $tkincdir && test -z $HAVE_TK_H ; then
> and $HAVE_TK_H is empty at that point. I don't know why it is empty but
> this is what is causing the error.
Ahh, yes.  Someone other than myself commented out the portion of
configure.in that would've set that variable...  Will fix.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
