[GRASS5] some BUGS/missing features
Markus Neteler neteler at geog.uni-hannover.de
Fri Jan 5 04:10:50 EST 2001
On Fri, Jan 05, 2001 at 08:17:21AM +0100, Radim Blazek wrote:
> Markus Neteler wrote:
> > > r.poly:
> > > r.poly respects the actual region settings, while r.line does not.
> > > I think that at least for the new vector lib every module should either
> > > use the actual region settings or ignore them. Not sure which is better.
> Vectors will ignore region except conversion into raster. I think that all vector
> modules ignore region now.
Well, but here we have raster-> vecktor conversion. So sensivity should be
o.k. as the source is raster.
> > > v.patch:
> > > v.patch uses the region info from the first vector map header and
> > > ignores the users region settings. As the region info from the map
> > > header is not reliable, this should be upgraded in a future vector lib
> > > redesign.
> > David, Radim?
> As I wrote in mail "new vector2" I propose move bounding box from dig
> into dig_plus.
> > > v.what/d.what.vect:
> > > v.what -i and d.what.vect are very similar and could be merged to one
> > > module? Not quite sure here.
> > Yes! Same thing with r.what/d.what.rast.
> > Or we decide that [rv].what are for script programming and
> > d.what.[vect|rast] are for interactive usage. Should get comparable module
> > behaviour.
> I think always merge modules if possible.
> > > v.alabel/v.llabel:
> > > v.alabel does bulk labeling of areas, v.llable does bulk labeling of
> > > line features. But there is no module to bulk label point features (site
> > > vectors in GRASS terminology). This function is needed if you want to
> > > intersect point features with area features (point-in-polygon test).
> > v.slabel? I have added a note into TODO.
> I want merge into v.category in g51 (and add: delete category, change
> category number, ...)
> (always merge modules if possible)
> > > v.cutregion:
> > > A module v.cutregion would be very handy to cut a vector map to the
> > > actual region. When i import from ascii vector files all vectors get
> > > imported, irrespectable if they fall into the current region or the
> > > whole GRASS region. This stems from the handling of the ascii header i
> > > think. With the new vector lib this could be handled correctly, but as a
> > > intermediate fix a module v.cutregion would be very useful.
> > I think this is on the way for 5.1 (David, Radim?).
> Cutting areas is not so simple and we have already v.cutter.
> I think that additional option for v.cutter
> -r    use current region insted of cutter map
> should help.
Yes, such an option for v.cutter would be good (and additionally have
v.cutter copying the labels to the new file).
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
