[GRASS5] new gmake system
Andreas Lange Andreas.Lange at Rhein-Main.de
Thu Jan 4 08:48:04 EST 2001
Hi again,
the new gmake system works very nice. Thanks a lot.
But some thinks should be noted in the INSTALL file:
If you compile grass on a clean system, gmake5 is installed only with
'make install'. So if the compile ('make') is finished and you try to
compile g3d and/or the postgreSQL modules, gmake5 is not found.
Compiling with bin.$ARCH/gmake5 does not work (not found error).
I can no longer compile src.contrib/GMSL/g3d, the -lXm library and
headers are not found any longer.
I did:
ln -s /usr/X11R6/LessTif/Motif1.2/include/Xm /usr/X11R6/include/Xm
The headers are found now, but not the library.
I have around:
/usr/X11R6/lib/libXmu.so.6
/usr/X11R6/lib/libXmu.so.6.1
/usr/X11R6/lib/libXm.so.2
/usr/X11R6/lib/libXm.so.2.1
/usr/X11R6/lib/libXmu.a
/usr/X11R6/lib/libXm.so.1
/usr/X11R6/lib/libXm.so.1.0.2
/usr/X11R6/LessTif/Motif1.2/lib/libXm.a
/usr/X11R6/LessTif/Motif1.2/lib/libXm.la
/usr/X11R6/LessTif/Motif1.2/lib/libXm.so
/usr/X11R6/LessTif/Motif1.2/lib/libXm.so.1
/usr/X11R6/LessTif/Motif1.2/lib/libXm.so.1.0.2
Where to change the path?
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
