[GRASS5] configure.in Wants testers...tk check
Markus Neteler neteler at geog.uni-hannover.de
Tue Jan 2 11:34:55 EST 2001
Hi John,
On Fri, Dec 29, 2000 at 06:23:48AM -0700, John Huddleston wrote:
> Grass list,
> I have debugged the problem with the tk check.  The configure
> script adds the -ltcl8.0 when it should be adding the -ltk8.0 for
> the Tk_MainWindow function.   In addition, the -lXt library
> is added which is not required under cygwin.   However, the
> X11 library lib directory was not included.   So, I have made some
> changes to the configure script as follows:
> added --with-x-includes=DIR
> added --with-x-libs=DIR
> for cygwin, this allowed me to add my /usr/x11R6.4 area
> modifed the tk check area to change the tcl8.0 to tk8.0
> plus I commented out the include conftest.h because there
> was no -I flag and it was not needed.
> I did not remove the -lXt since Linux or Sun may require that
> for the tk library.  Cygwin does not need it.
> The commit on the file is not going very quickly.   If it hangs
> I will send the file separately to Markus and he can commit
> it for us.
checking Tcl include dirs... -I/usr/include
checking Tk include dirs... -I/usr/include
checking Tcl/Tk library dirs... -L/usr/lib
checking for Tk_MainWindow in -ltk8.3... yes
it works well now! Congrats and many thanks for the fix.
I'll try my other machine later.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
