[GRASS5] More on g.region errors
Rich Shepard rshepard at appl-ecosys.com
Mon Jul 30 23:12:15 EDT 2001
On Mon, 30 Jul 2001, Eric G. Miller wrote:
> >   In PROJ_UNITS, the datum is defined as NAD83 and the ellipsoid as clark66.
> 		       This is clearly wrong!  NAD83 uses the GRS80
> 		       ellipsoid.  GRS80 is almost identical to the
> 		       WGS84 ellipsoid, btw.
Eric,
  I didn't check, so I thank you for pointing this out. I took the values in
PROJ_INFO as written there by r.in.gdal.
> Despite, the error noted above.  I can't say why you're getting garbage
> values output (though that G_free() was clearly an error).
  I just re-compiled GRASS5 with Glynn's corrections made to get_window.c.
I've been busy with other things this evening and haven't tried bringing in
another .e00 file. Tomorrow is another day.
Rich
Dr. Richard B. Shepard, President
                       Applied Ecosystem Services, Inc. (TM)
            2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
 + 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
                 Making environmentally-responsible mining happen.
