[GRASS5] Recommended tweak for 5.1
Markus Neteler neteler at geog.uni-hannover.de
Fri Mar 30 11:27:54 EST 2001
Michel,
On Fri, Mar 30, 2001 at 03:39:57PM +0000, Michel Wurtz wrote:
> David D Gray wrote:
> > Michel
> > Work has already begun on changing the v.*.ascii spec. You can see code
> > and examples in the grass51 tree. The whole setup uses indexing to refer
> > to attributes (including if required ID), and will also be able to hold
> > multiple types of vector primitive.
> OK, thanks to you and Radim who pointed this to me (I didn't look recently
> at the code and probably forget the mails anouncing that). but maybe I
> must load the 5.1 tree (is there a different CVS tree than for 5.0 ?)
cvs -z3 co grass51
will get it for you.
Cheers
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
