[GRASS5] GRASS 5.0.0pre1 compilation on HP-UX
Eric Mitchell emitchell at altaira.com
Fri May 25 12:19:17 EDT 2001
I don't think that autoconf likes multiple directories for standard
--with-xxx-includes/libs settings.  I think the "proper" thing
would be to use separate --with-tcl=/path/to/tclConfig.sh and
--with-tk=/path/to/tkConfig.sh options.  The xxxConfig.sh scripts
set up the required include directories, libraries, linker flags,
etc.  The autoconf script would source the xxxConfig.sh script,
and substitute for the defined variables in the appropriate .in
files.  I've attached a tcl.m4 autoconf macro file that deals
with --with-tcl and --with-tk options.
When I ran into problems like these, I used to just fix the
inevitable makefile problems as i found them.
| Eric B. Mitchell         mailto:emitchell at altaira.com |
| tel: (301) 809 - 3534    Altair Aerospace Corporation |
| tel: (800) 7 - ALTAIR    4201 Northview Dr. Suite 410 |
| fax: (301) 805 - 8122    Bowie, MD  20716             |
              ,___
          /"\  / o=\  /"""---===/
         /   \_/  \__/   ---===/
         |    //\   || /""TT""/ //\   || ||""\
         |   //  \  ||    ||   //  \  || ||__/
         |  //--==\ |L--/ ||  //--==\ || || "=,
           \____---===/
# SC_PATH_TCLCONFIG --
#	Locate the tclConfig.sh file and perform a sanity check on
#	the Tcl compile flags
# Arguments:
#	none
# Results:
#	Adds the following arguments to configure:
#		--with-tcl=...
#	Defines the following vars:
#		TCL_BIN_DIR	Full path to the directory containing
#				the tclConfig.sh file
AC_DEFUN(SC_PATH_TCLCONFIG, [
    # Ok, lets find the tcl configuration
    # First, look for one uninstalled.
    # the alternative search directory is invoked by --with-tcl
    if test x"${no_tcl}" = x ; then
	# we reset no_tcl in case something fails here
	no_tcl=true
	AC_ARG_WITH(tcl, [  --with-tcl              directory containing tcl configuration (tclConfig.sh)], with_tclconfig=${withval})
	AC_MSG_CHECKING([for Tcl configuration])
	AC_CACHE_VAL(ac_cv_c_tclconfig,[
	    # First check to see if --with-tclconfig was specified.
	    if test x"${with_tclconfig}" != x ; then
		if test -f "${with_tclconfig}/tclConfig.sh" ; then
		    ac_cv_c_tclconfig=`(cd ${with_tclconfig}; pwd)`
		else
		    AC_MSG_ERROR([${with_tclconfig} directory doesn't contain tclConfig.sh])
		fi
	    fi
	    # then check for a private Tcl installation
	    if test x"${ac_cv_c_tclconfig}" = x ; then
		for i in \
			../tcl \
			`ls -dr ../tcl[[8-9]].[[0-9]]* 2>/dev/null` \
			../../tcl \
			`ls -dr ../../tcl[[8-9]].[[0-9]]* 2>/dev/null` \
			../../../tcl \
			`ls -dr ../../../tcl[[8-9]].[[0-9]]* 2>/dev/null` ; do
		    if test -f "$i/unix/tclConfig.sh" ; then
			ac_cv_c_tclconfig=`(cd $i/unix; pwd)`
			break
		    fi
		done
	    fi
	    # check in a few common install locations
		for i in `ls -d ${prefix}/lib 2>/dev/null` \
			`ls -d /usr/local/lib 2>/dev/null` ; do
		    if test -f "$i/tclConfig.sh" ; then
			ac_cv_c_tclconfig=`(cd $i; pwd)`
			break
		    fi
		done
	    fi
	    # check in a few other private locations
	    if test x"${ac_cv_c_tcliconfig}" = x ; then
		for i in \
			${srcdir}/../tcl \
			`ls -dr ${srcdir}/../tcl[[8-9]].[[0-9]]* 2>/dev/null` ; do
		    break
		fi
		done
	    fi
	    TCL_BIN_DIR="# no Tcl configs found"
	    AC_MSG_WARN(Can't find Tcl configuration definitions)
	    exit 0
	else
	    no_tcl=
	    TCL_BIN_DIR=${ac_cv_c_tclconfig}
	    AC_MSG_RESULT(found $TCL_BIN_DIR/tclConfig.sh)
	fi
    fi
# SC_PATH_TKCONFIG --
#	Locate the tkConfig.sh file
# Arguments:
#	none
# Results:
#		--with-tk=...
#		TK_BIN_DIR	Full path to the directory containing
#				the tkConfig.sh file
AC_DEFUN(SC_PATH_TKCONFIG, [
    # Ok, lets find the tk configuration
    # the alternative search directory is invoked by --with-tk
    if test x"${no_tk}" = x ; then
	# we reset no_tk in case something fails here
	no_tk=true
	AC_ARG_WITH(tk, [  --with-tk               directory containing tk configuration (tkConfig.sh)], with_tkconfig=${withval})
	AC_MSG_CHECKING([for Tk configuration])
	AC_CACHE_VAL(ac_cv_c_tkconfig,[
	    # First check to see if --with-tkconfig was specified.
	    if test x"${with_tkconfig}" != x ; then
		if test -f "${with_tkconfig}/tkConfig.sh" ; then
		    ac_cv_c_tkconfig=`(cd ${with_tkconfig}; pwd)`
		else
		    AC_MSG_ERROR([${with_tkconfig} directory doesn't contain tkConfig.sh])
		fi
	    fi
	    # then check for a private Tk library
	    if test x"${ac_cv_c_tkconfig}" = x ; then
		for i in \
			../tk \
			`ls -dr ../tk[[8-9]].[[0-9]]* 2>/dev/null` \
			../../tk \
			`ls -dr ../../tk[[8-9]].[[0-9]]* 2>/dev/null` \
			../../../tk \
			`ls -dr ../../../tk[[8-9]].[[0-9]]* 2>/dev/null` ; do
		    if test -f "$i/unix/tkConfig.sh" ; then
			ac_cv_c_tkconfig=`(cd $i/unix; pwd)`
			break
		    fi
		done
	    fi
		    if test -f "$i/tkConfig.sh" ; then
			ac_cv_c_tkconfig=`(cd $i; pwd)`
			break
		    fi
		done
	    fi
		for i in \
			${srcdir}/../tk \
			`ls -dr ${srcdir}/../tk[[8-9]].[[0-9]]* 2>/dev/null` ; do
			break
		    fi
		done
	    fi
	    TK_BIN_DIR="# no Tk configs found"
	    AC_MSG_WARN(Can't find Tk configuration definitions)
	    exit 0
	else
	    no_tk=
	    TK_BIN_DIR=${ac_cv_c_tkconfig}
	    AC_MSG_RESULT(found $TK_BIN_DIR/tkConfig.sh)
	fi
    fi
# SC_LOAD_TCLCONFIG --
#	Load the tclConfig.sh file
# Arguments:
#	Requires the following vars to be set:
#		TCL_BIN_DIR
# Results:
#	Subst the following vars:
#		TCL_BIN_DIR
#		TCL_SRC_DIR
#		TCL_LIB_FILE
AC_DEFUN(SC_LOAD_TCLCONFIG, [
    AC_MSG_CHECKING([for existence of $TCL_BIN_DIR/tclConfig.sh])
    if test -f "$TCL_BIN_DIR/tclConfig.sh" ; then
        AC_MSG_RESULT([loading])
	. $TCL_BIN_DIR/tclConfig.sh
    else
        AC_MSG_RESULT([file not found])
    fi
    # The eval is required to do the TCL_DBGX substitution in the
    # TCL_LIB_FILE variable
    eval TCL_LIB_FILE=${TCL_LIB_FILE}
    eval TCL_LIB_FLAG=${TCL_LIB_FLAG}
    AC_SUBST(TCL_BIN_DIR)
    AC_SUBST(TCL_SRC_DIR)
    AC_SUBST(TCL_LIB_FILE)
# SC_LOAD_TKCONFIG --
#	Load the tkConfig.sh file
# Arguments:
#		TK_BIN_DIR
# Results:
#	Sets the following vars that should be in tkConfig.sh:
#		TK_BIN_DIR
AC_DEFUN(SC_LOAD_TKCONFIG, [
    AC_MSG_CHECKING([for existence of $TCLCONFIG])
    if test -f "$TK_BIN_DIR/tkConfig.sh" ; then
        AC_MSG_CHECKING([loading $TK_BIN_DIR/tkConfig.sh])
	. $TK_BIN_DIR/tkConfig.sh
    else
        AC_MSG_RESULT([could not find $TK_BIN_DIR/tkConfig.sh])
    fi
    AC_SUBST(TK_BIN_DIR)
    AC_SUBST(TK_SRC_DIR)
    AC_SUBST(TK_LIB_FILE)
# SC_ENABLE_GCC --
#	Allows the use of GCC if available
# Arguments:
#	none
# Results:
#		--enable-gcc
#	Sets the following vars:
#		CC	Command to use for the compiler
AC_DEFUN(SC_ENABLE_GCC, [
    AC_ARG_ENABLE(gcc, [  --enable-gcc            allow use of gcc if available [--disable-gcc]],
	[ok=$enableval], [ok=no])
    if test "$ok" = "yes"; then
	CC=gcc
	AC_PROG_CC
    else
	CC=${CC-cc}
    fi
# SC_ENABLE_SHARED --
#	Allows the building of shared libraries
# Arguments:
#	none
# Results:
#		--enable-shared=yes|no
#		STATIC_BUILD	Used for building import/export libraries
#				on Windows.
#		SHARED_BUILD	Value of 1 or 0
AC_DEFUN(SC_ENABLE_SHARED, [
    AC_MSG_CHECKING([how to build libraries])
    AC_ARG_ENABLE(shared,
	[  --enable-shared         build and link with shared libraries [--enable-shared]],
	[tcl_ok=$enableval], [tcl_ok=yes])
    if test "${enable_shared+set}" = set; then
	enableval="$enable_shared"
	tcl_ok=$enableval
    else
	tcl_ok=yes
    fi
    if test "$tcl_ok" = "yes" ; then
	AC_MSG_RESULT([shared])
	SHARED_BUILD=1
    else
	AC_MSG_RESULT([static])
	SHARED_BUILD=0
	AC_DEFINE(STATIC_BUILD)
    fi
# SC_ENABLE_THREADS --
#	Specify if thread support should be enabled
# Arguments:
#	none
# Results:
#		--enable-threads
#		THREADS_LIBS	Thread library(s)
#		TCL_THREADS
#		_REENTRANT
AC_DEFUN(SC_ENABLE_THREADS, [
    AC_MSG_CHECKING(for building with threads)
    AC_ARG_ENABLE(threads, [  --enable-threads        build with threads],
	[tcl_ok=$enableval], [tcl_ok=no])
    if test "$tcl_ok" = "yes"; then
	AC_MSG_RESULT(yes)
	TCL_THREADS=1
	AC_DEFINE(TCL_THREADS)
	AC_DEFINE(_REENTRANT)
	AC_CHECK_LIB(pthread,pthread_mutex_init,tcl_ok=yes,tcl_ok=no)
	    # The space is needed
	    THREADS_LIBS=" -lpthread"
	else
	    TCL_THREADS=0
	    AC_MSG_WARN("Don t know how to find pthread lib on your system - you must disable thread support or edit the LIBS in the Makefile...")
	fi
    else
	TCL_THREADS=0
	AC_MSG_RESULT(no (default))
    fi
# SC_ENABLE_SYMBOLS --
#	Specify if debugging symbols should be used
# Arguments:
#	none
#		CFLAGS_DEBUG
#		CFLAGS_OPTIMIZE
#		LDFLAGS_DEBUG
#		LDFLAGS_OPTIMIZE
# Results:
#		--enable-symbols
#		CFLAGS_DEFAULT	Sets to CFLAGS_DEBUG if true
#				Sets to CFLAGS_OPTIMIZE if false
#		LDFLAGS_DEFAULT	Sets to LDFLAGS_DEBUG if true
#				Sets to LDFLAGS_OPTIMIZE if false
#		DBGX		Debug library extension
AC_DEFUN(SC_ENABLE_SYMBOLS, [
    AC_MSG_CHECKING([for build with symbols])
    AC_ARG_ENABLE(symbols, [  --enable-symbols        build with debugging symbols [--disable-symbols]],    [tcl_ok=$enableval], [tcl_ok=no])
	CFLAGS_DEFAULT="${CFLAGS_DEBUG}"
	LDFLAGS_DEFAULT="${LDFLAGS_DEBUG}"
	DBGX=g
	AC_MSG_RESULT([yes])
    else
	CFLAGS_DEFAULT="${CFLAGS_OPTIMIZE}"
	LDFLAGS_DEFAULT="${LDFLAGS_OPTIMIZE}"
	DBGX=""
	AC_MSG_RESULT([no])
    fi
# SC_CONFIG_CFLAGS
#	Try to determine the proper flags to pass to the compiler
#	for building shared libraries and other such nonsense.
# Arguments:
#	none
# Results:
#       DL_OBJS -       Name of the object file that implements dynamic
#                       loading for Tcl on this system.
#       DL_LIBS -       Library file(s) to include in tclsh and other base
#                       applications in order for the "load" command to work.
#       LDFLAGS -      Flags to pass to the compiler when linking object
#                       files into an executable application binary such
#                       as tclsh.
#       LD_SEARCH_FLAGS-Flags to pass to ld, such as "-R /usr/local/tcl/lib",
#                       that tell the run-time dynamic linker where to look
#                       for shared libraries such as libtcl.so.  Depends on
#                       the variable LIB_RUNTIME_DIR in the Makefile.
#       MAKE_LIB -      Command to execute to build the Tcl library;
#                       differs depending on whether or not Tcl is being
#                       compiled as a shared library.
#       SHLIB_CFLAGS -  Flags to pass to cc when compiling the components
#                       of a shared library (may request position-independent
#                       code, among other things).
#       SHLIB_LD -      Base command to use for combining object files
#                       into a shared library.
#       SHLIB_LD_LIBS - Dependent libraries for the linker to scan when
#                       creating shared libraries.  This symbol typically
#                       goes at the end of the "ld" commands that build
#                       shared libraries. The value of the symbol is
#                       "${LIBS}" if all of the dependent libraries should
#                       be specified when creating a shared library.  If
#                       dependent libraries should not be specified (as on
#                       SunOS 4.x, where they cause the link to fail, or in
#                       general if Tcl and Tk aren't themselves shared
#                       libraries), then this symbol has an empty string
#                       as its value.
#       SHLIB_SUFFIX -  Suffix to use for the names of dynamically loadable
#                       extensions.  An empty string means we don't know how
#                       to use shared libraries on this platform.
#       TCL_LIB_FILE -  Name of the file that contains the Tcl library, such
#                       as libtcl7.8.so or libtcl7.8.a.
#       TCL_LIB_SUFFIX -Specifies everything that comes after the "libtcl"
#                       in the shared library name, using the $VERSION variable
#                       to put the version in the right place.  This is used
#                       by platforms that need non-standard library names.
#                       Examples:  ${VERSION}.so.1.1 on NetBSD, since it needs
#                       to have a version after the .so, and ${VERSION}.a
#                       on AIX, since the Tcl shared library needs to have
#                       a .a extension whereas shared objects for loadable
#                       extensions have a .so extension.  Defaults to
#                       ${VERSION}${SHLIB_SUFFIX}.
#       TCL_NEEDS_EXP_FILE -
#                       1 means that an export file is needed to link to a
#                       shared library.
#       TCL_EXP_FILE -  The name of the installed export / import file which
#                       should be used to link to the Tcl shared library.
#                       Empty if Tcl is unshared.
#       TCL_BUILD_EXP_FILE -
#                       The name of the built export / import file which
#	CFLAGS_DEBUG -
#			Flags used when running the compiler in debug mode
#	CFLAGS_OPTIMIZE -
#			Flags used when running the compiler in optimize mode
#	EXTRA_CFLAGS
#	Subst's the following vars:
#		DL_LIBS
#		CFLAGS_DEBUG
#		CFLAGS_OPTIMIZE
AC_DEFUN(SC_CONFIG_CFLAGS, [
    # Step 0: Enable 64 bit support?
    AC_MSG_CHECKING([if 64bit support is enabled])
    AC_ARG_ENABLE(64bit,[  --enable-64bit          enable 64bit support],,enableval="no")
    if test "$enableval" = "yes"; then
	AC_MSG_RESULT(Will compile with 64bit support)
	do64bit=yes
    else
	do64bit=no
    fi
    AC_MSG_RESULT($do64bit)
    # Step 1: set the variable "system" to hold the name and version number
    # for the system.  This can usually be done via the "uname" command, but
    # there are a few systems, like Next, where this doesn't work.
    AC_MSG_CHECKING([system version (for dynamic loading)])
    if test -f /usr/lib/NextStep/software_version; then
	system=NEXTSTEP-`awk '/3/,/3/' /usr/lib/NextStep/software_version`
    else
	system=`uname -s`-`uname -r`
	if test "$?" -ne 0 ; then
	    AC_MSG_RESULT([unknown (can't find uname command)])
	    system=unknown
	else
	    # Special check for weird MP-RAS system (uname returns weird
	    # results, and the version is kept in special file).
	    if test -r /etc/.relid -a "X`uname -n`" = "X`uname -s`" ; then
		system=MP-RAS-`awk '{print $3}' /etc/.relid'`
	    fi
	    if test "`uname -s`" = "AIX" ; then
		system=AIX-`uname -v`.`uname -r`
	    fi
	    AC_MSG_RESULT($system)
	fi
    fi
    # Step 2: check for existence of -ldl library.  This is needed because
    # Linux can use either -ldl or -ldld for dynamic loading.
    AC_CHECK_LIB(dl, dlopen, have_dl=yes, have_dl=no)
    # Step 3: set configuration options based on system name and version.
    do64bit_ok=no
    fullSrcDir=`cd $srcdir; pwd`
    EXTRA_CFLAGS=""
    TCL_EXPORT_FILE_SUFFIX=""
    UNSHARED_LIB_SUFFIX=""
    TCL_TRIM_DOTS='`echo ${VERSION} | tr -d .`'
    ECHO_VERSION='`echo ${VERSION}`'
    TCL_LIB_VERSIONS_OK=ok
    CFLAGS_DEBUG=-g
    CFLAGS_OPTIMIZE=-O
    TCL_NEEDS_EXP_FILE=0
    TCL_BUILD_EXP_FILE=""
    TCL_EXP_FILE=""
    STLIB_LD="ar cr"
    case $system in
	AIX-4.[[2-9]])
	    SHLIB_CFLAGS=""
	    SHLIB_LD="$fullSrcDir/ldAix /bin/ld -bhalt:4 -bM:SRE -bE:lib.exp -H512 -T512 -bnoentry"
	    SHLIB_LD_LIBS='${LIBS}'
	    SHLIB_SUFFIX=".so"
	    DL_OBJS="tclLoadDl.o"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    LD_SEARCH_FLAGS='-L${LIB_RUNTIME_DIR}'
	    TCL_NEEDS_EXP_FILE=1
	    TCL_EXPORT_FILE_SUFFIX='${VERSION}\$\{DBGX\}.exp'
	AIX-*)
	    SHLIB_CFLAGS=""
	    SHLIB_SUFFIX=".so"
	    LIBOBJS="$LIBOBJS tclLoadAix.o"
	    DL_LIBS="-lld"
	    LDFLAGS=""
	BSD/OS-2.1*|BSD/OS-3*)
	    SHLIB_CFLAGS=""
	    SHLIB_LD="shlicc -r"
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	BSD/OS-4.*)
	    SHLIB_CFLAGS="-export-dynamic -fPIC"
	    SHLIB_LD="cc -shared"
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS="-export-dynamic"
	    LD_SEARCH_FLAGS=""
	dgux*)
	    SHLIB_CFLAGS="-K PIC"
	    SHLIB_LD="cc -G"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	HP-UX-*.08.*|HP-UX-*.09.*|HP-UX-*.10.*|HP-UX-*.11.*)
	    SHLIB_SUFFIX=".sl"
	    AC_CHECK_LIB(dld, shl_load, tcl_ok=yes, tcl_ok=no)
	    if test "$tcl_ok" = yes; then
		SHLIB_CFLAGS="+z"
		SHLIB_LD="ld -b"
		SHLIB_LD_LIBS=""
		DL_OBJS="tclLoadShl.o"
		DL_LIBS="-ldld"
		LDFLAGS="-Wl,-E"
		LD_SEARCH_FLAGS='-Wl,+s,+b,${LIB_RUNTIME_DIR}:.'
	    fi
	IRIX-4.*)
	    SHLIB_CFLAGS="-G 0"
	    SHLIB_SUFFIX=".a"
	    SHLIB_LD="echo tclLdAout $CC \{$SHLIB_CFLAGS\} | `pwd`/tclsh -r -G 0"
	    DL_OBJS="tclLoadAout.o"
	    DL_LIBS=""
	    LDFLAGS="-Wl,-D,08000000"
	    SHARED_LIB_SUFFIX='${VERSION}\$\{DBGX\}.a'
	IRIX-5.*|IRIX-6.*|IRIX64-6.5*)
	    SHLIB_CFLAGS=""
	    SHLIB_LD="ld -n32 -shared -rdata_shared"
	    SHLIB_SUFFIX=".so"
	    DL_LIBS=""
	    LD_SEARCH_FLAGS='-Wl,-rpath,${LIB_RUNTIME_DIR}'
	    if test "$CC" = "gcc" -o `$CC -v 2>&1 | grep -c gcc` != "0" ; then
		EXTRA_CFLAGS="-mabi=n32"
		LDFLAGS="-mabi=n32"
	    else
		case $system in
		    IRIX-6.3)
			# Use to build 6.2 compatible binaries on 6.3.
			EXTRA_CFLAGS="-n32 -D_OLD_TERMIOS"
			EXTRA_CFLAGS="-n32"
		esac
		LDFLAGS="-n32"
	    fi
	IRIX64-6.*)
	    SHLIB_CFLAGS=""
	    SHLIB_LD="ld -32 -shared -rdata_shared"
	    SHLIB_SUFFIX=".so"
	    DL_LIBS=""
	    LDFLAGS=""
	Linux*)
	    SHLIB_CFLAGS="-fPIC"
	    SHLIB_SUFFIX=".so"
	    # egcs-2.91.66 on Redhat Linux 6.0 generates lots of warnings
	    # when you inline the string and math operations.  Turn this off to
	    # get rid of the warnings.
	    CFLAGS_OPTIMIZE="${CFLAGS_OPTIMIZE} -D__NO_STRING_INLINES -D__NO_MATH_INLINES"
	    if test "$have_dl" = yes; then
		SHLIB_LD="${CC} -shared"
		DL_LIBS="-ldl"
		LDFLAGS="-rdynamic"
	    else
		AC_CHECK_HEADER(dld.h, [
		    SHLIB_LD="ld -shared"
		    DL_OBJS="tclLoadDld.o"
		    DL_LIBS="-ldld"
		    LDFLAGS=""
		    LD_SEARCH_FLAGS=""])
	    fi
	    if test "`uname -m`" = "alpha" ; then
		EXTRA_CFLAGS="-mieee"
	    fi
	MP-RAS-02*)
	    SHLIB_LD="cc -G"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	MP-RAS-*)
	    SHLIB_LD="cc -G"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS="-Wl,-Bexport"
	    LD_SEARCH_FLAGS=""
	NetBSD-*|FreeBSD-[[1-2]].*|OpenBSD-*)
	    # Not available on all versions:  check for include file.
	    AC_CHECK_HEADER(dlfcn.h, [
		SHLIB_CFLAGS="-fpic"
		SHLIB_LD="ld -Bshareable -x"
		SHLIB_LD_LIBS=""
		SHLIB_SUFFIX=".so"
		DL_LIBS=""
		LDFLAGS=""
		LD_SEARCH_FLAGS=""
		SHARED_LIB_SUFFIX='${TCL_TRIM_DOTS}\$\{DBGX\}.so.1.0'
		SHLIB_CFLAGS=""
		SHLIB_LD="echo tclLdAout $CC \{$SHLIB_CFLAGS\} | `pwd`/tclsh -r"
		SHLIB_SUFFIX=".a"
		DL_LIBS=""
		LDFLAGS=""
		SHARED_LIB_SUFFIX='${TCL_TRIM_DOTS}\$\{DBGX\}.a'
	    # FreeBSD doesn't handle version numbers with dots.
	    UNSHARED_LIB_SUFFIX='${TCL_TRIM_DOTS}\$\{DBGX\}.a'
	    TCL_LIB_VERSIONS_OK=nodots
	FreeBSD-*)
	    # FreeBSD 3.* and greater have ELF.
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS=""
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	NEXTSTEP-*)
	    SHLIB_CFLAGS=""
	    SHLIB_LD="cc -nostdlib -r"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_OBJS="tclLoadNext.o"
	    DL_LIBS=""
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	OS/390-*)
	    CFLAGS_OPTIMIZE=""      # Optimizer is buggy
	    AC_DEFINE(_OE_SOCKETS)  # needed in sys/socket.h
	OSF1-1.0|OSF1-1.1|OSF1-1.2)
	    # OSF/1 1.[012] from OSF, and derivatives, including Paragon OSF/1
	    SHLIB_CFLAGS=""
	    # Hack: make package name same as library name
	    SHLIB_LD='ld -R -export $@:'
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_OBJS="tclLoadOSF.o"
	    DL_LIBS=""
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	OSF1-1.*)
	    # OSF/1 1.3 from OSF using ELF, and derivatives, including AD2
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS=""
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	OSF1-V*)
	    # Digital OSF/1
	    SHLIB_CFLAGS=""
	    SHLIB_LD='ld -shared -expect_unresolved "*"'
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS=""
	    LDFLAGS=""
	RISCos-*)
	    SHLIB_CFLAGS="-G 0"
	    SHLIB_SUFFIX=".a"
	    DL_LIBS=""
	SCO_SV-3.2*)
	    # Note, dlopen is available only on SCO 3.2.5 and greater.  However,
	    # this test works, since "uname -s" was non-standard in 3.2.4 and
	    # below.
	    SHLIB_CFLAGS="-Kpic -belf"
	    SHLIB_LD="ld -G"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS=""
	    LDFLAGS="-belf -Wl,-Bexport"
	    LD_SEARCH_FLAGS=""
	SINIX*5.4*)
	    SHLIB_LD="cc -G"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    LD_SEARCH_FLAGS=""
	SunOS-4*)
	    SHLIB_CFLAGS="-PIC"
	    SHLIB_LD="ld"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    # SunOS can't handle version numbers with dots in them in library
	    # specs, like -ltcl7.5, so use -ltcl75 instead.  Also, it
	    # requires an extra version number at the end of .so file names.
	    # So, the library has to have a name like libtcl75.so.1.0
	SunOS-5.[[0-6]]*)
	    SHLIB_CFLAGS="-KPIC"
	    SHLIB_LD="/usr/ccs/bin/ld -G -z text"
	    # Note: need the LIBS below, otherwise Tk won't find Tcl's
	    # symbols when dynamically loaded into tclsh.
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    LDFLAGS=""
	    LD_SEARCH_FLAGS='-Wl,-R,${LIB_RUNTIME_DIR}'
	SunOS-5*)
	    LDFLAGS=""
	    do64bit_ok=no
	    if test "$do64bit" = "yes" ; then
	    arch=`isainfo`
	    if test "$arch" = "sparcv9 sparc" ; then
		if test "$CC" != "gcc" -a `$CC -v 2>&1 | grep -c gcc` = "0" ; then
		do64bit_ok=yes
		EXTRA_CFLAGS="-xarch=v9"
		LDFLAGS="-xarch=v9"
		else
		AC_MSG_WARN("64bit mode not supported using GCC on $system")
		fi
	    else
		AC_MSG_WARN("64bit mode only supported sparcv9 system")
	    fi
	    fi
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    else
		LD_SEARCH_FLAGS='-R ${LIB_RUNTIME_DIR}'
	    fi
	ULTRIX-4.*)
	    SHLIB_CFLAGS="-G 0"
	    SHLIB_SUFFIX=".a"
	    DL_LIBS=""
	UNIX_SV* | UnixWare-5*)
	    SHLIB_LD="cc -G"
	    SHLIB_LD_LIBS=""
	    SHLIB_SUFFIX=".so"
	    DL_LIBS="-ldl"
	    # Some UNIX_SV* systems (unixware 1.1.2 for example) have linkers
	    # that don't grok the -Bexport option.  Test that it does.
	    hold_ldflags=$LDFLAGS
	    AC_MSG_CHECKING(for ld accepts -Bexport flag)
	    LDFLAGS="${LDFLAGS} -Wl,-Bexport"
	    AC_TRY_LINK(, [int i;], found=yes, found=no)
	    LDFLAGS=$hold_ldflags
	    AC_MSG_RESULT($found)
	    if test $found = yes; then
	    else
	    LDFLAGS=""
	    fi
	    LD_SEARCH_FLAGS=""
    esac
    if test "$do64bit" = "yes" -a "$do64bit_ok" = "no" ; then
    AC_MSG_WARN("64bit support being disabled -- not supported on this platform")
    fi
    # Step 4: If pseudo-static linking is in use (see K. B. Kenny, "Dynamic
    # Loading for Tcl -- What Became of It?".  Proc. 2nd Tcl/Tk Workshop,
    # New Orleans, LA, Computerized Processes Unlimited, 1994), then we need
    # to determine which of several header files defines the a.out file
    # format (a.out.h, sys/exec.h, or sys/exec_aout.h).  At present, we
    # support only a file format that is more or less version-7-compatible.
    # In particular,
    #	- a.out files must begin with `struct exec'.
    #	- the N_TXTOFF on the `struct exec' must compute the seek address
    #	  of the text segment
    #	- The `struct exec' must contain a_magic, a_text, a_data, a_bss
    #	  and a_entry fields.
    # The following compilation should succeed if and only if either sys/exec.h
    # or a.out.h is usable for the purpose.
    # Note that the modified COFF format used on MIPS Ultrix 4.x is usable; the
    # `struct exec' includes a second header that contains information that
    # duplicates the v7 fields that are needed.
    if test "x$DL_OBJS" = "xtclLoadAout.o" ; then
	AC_MSG_CHECKING(sys/exec.h)
	AC_TRY_COMPILE([#include <sys/exec.h>],[
	    struct exec foo;
	    unsigned long seek;
	    int flag;
#if defined(__mips) || defined(mips)
	    seek = N_TXTOFF (foo.ex_f, foo.ex_o);
#else
	    seek = N_TXTOFF (foo);
#endif
	    flag = (foo.a_magic == OMAGIC);
	    return foo.a_text + foo.a_data + foo.a_bss + foo.a_entry;
    ], tcl_ok=usable, tcl_ok=unusable)
	AC_MSG_RESULT($tcl_ok)
	if test $tcl_ok = usable; then
	    AC_DEFINE(USE_SYS_EXEC_H)
	else
	    AC_MSG_CHECKING(a.out.h)
	    AC_TRY_COMPILE([#include <a.out.h>],[
		struct exec foo;
		unsigned long seek;
		int flag;
#else
#endif
		AC_DEFINE(USE_A_OUT_H)
	    else
		AC_MSG_CHECKING(sys/exec_aout.h)
		AC_TRY_COMPILE([#include <sys/exec_aout.h>],[
		    struct exec foo;
		    unsigned long seek;
		    int flag;
#else
#endif
		    flag = (foo.a_midmag == OMAGIC);
		    AC_DEFINE(USE_SYS_EXEC_AOUT_H)
		else
		    DL_OBJS=""
		fi
	    fi
	fi
    fi
    # Step 5: disable dynamic loading if requested via a command-line switch.
    AC_ARG_ENABLE(load, [  --disable-load          disallow dynamic loading and "load" command],
    if test "$tcl_ok" = "no"; then
	DL_OBJS=""
    fi
    if test "x$DL_OBJS" != "x" ; then
	BUILD_DLTEST="\$(DLTEST_TARGETS)"
    else
	echo "Can't figure out how to do dynamic loading or shared libraries"
	echo "on this system."
	SHLIB_CFLAGS=""
	SHLIB_LD=""
	SHLIB_SUFFIX=""
	DL_OBJS="tclLoadNone.o"
	DL_LIBS=""
	LDFLAGS=""
	LD_SEARCH_FLAGS=""
	BUILD_DLTEST=""
    fi
    # If we're running gcc, then change the C flags for compiling shared
    # libraries to the right flags for gcc, instead of those for the
    # standard manufacturer compiler.
    if test "$DL_OBJS" != "tclLoadNone.o" ; then
	    case $system in
		AIX-*)
		BSD/OS*)
		IRIX*)
		NetBSD-*|FreeBSD-*|OpenBSD-*)
		RISCos-*)
		ULTRIX-4.*)
	    esac
	fi
    fi
    if test "$SHARED_LIB_SUFFIX" = "" ; then
	SHARED_LIB_SUFFIX='${VERSION}\$\{DBGX\}${SHLIB_SUFFIX}'
    fi
    if test "$UNSHARED_LIB_SUFFIX" = "" ; then
	UNSHARED_LIB_SUFFIX='${VERSION}\$\{DBGX\}.a'
    fi
    AC_SUBST(DL_LIBS)
    AC_SUBST(CFLAGS_DEBUG)
    AC_SUBST(CFLAGS_OPTIMIZE)
# SC_SERIAL_PORT
#	Determine which interface to use to talk to the serial port.
#	Note that #include lines must begin in leftmost column for
#	some compilers to recognize them as preprocessor directives.
# Arguments:
#	none
# Results:
#	Defines only one of the following vars:
#		USE_TERMIOS
#		USE_TERMIO
#		USE_SGTTY
AC_DEFUN(SC_SERIAL_PORT, [
    AC_MSG_CHECKING([termios vs. termio vs. sgtty])
    AC_TRY_RUN([
#include <termios.h>
main()
    struct termios t;
    if (tcgetattr(0, &t) == 0) {
	cfsetospeed(&t, 0);
	t.c_cflag |= PARENB | PARODD | CSIZE | CSTOPB;
	return 0;
    return 1;
}], tk_ok=termios, tk_ok=no, tk_ok=no)
    if test $tk_ok = termios; then
	AC_DEFINE(USE_TERMIOS)
    else
	AC_TRY_RUN([
#include <termio.h>
main()
    struct termio t;
    if (ioctl(0, TCGETA, &t) == 0) {
	t.c_cflag |= CBAUD | PARENB | PARODD | CSIZE | CSTOPB;
	return 0;
    return 1;
    }], tk_ok=termio, tk_ok=no, tk_ok=no)
    if test $tk_ok = termio; then
	AC_DEFINE(USE_TERMIO)
    else
	AC_TRY_RUN([
#include <sgtty.h>
main()
    struct sgttyb t;
    if (ioctl(0, TIOCGETP, &t) == 0) {
	t.sg_ospeed = 0;
	t.sg_flags |= ODDP | EVENP | RAW;
	return 0;
    return 1;
}], tk_ok=sgtty, tk_ok=none, tk_ok=none)
    if test $tk_ok = sgtty; then
	AC_DEFINE(USE_SGTTY)
    fi
    fi
    fi
    AC_MSG_RESULT($tk_ok)
# SC_MISSING_POSIX_HEADERS
#	Supply substitutes for missing POSIX header files.  Special
#	notes:
#	    - stdlib.h doesn't define strtol, strtoul, or
#	      strtod insome versions of SunOS
#	    - some versions of string.h don't declare procedures such
#	      as strstr
# Arguments:
#	none
# Results:
#	Defines some of the following vars:
#		NO_DIRENT_H
#		NO_ERRNO_H
#		NO_VALUES_H
#		NO_LIMITS_H
#		NO_STDLIB_H
#		NO_STRING_H
#		NO_SYS_WAIT_H
#		NO_DLFCN_H
#		HAVE_UNISTD_H
#		HAVE_SYS_PARAM_H
#		HAVE_STRING_H ?
AC_DEFUN(SC_MISSING_POSIX_HEADERS, [
    AC_MSG_CHECKING(dirent.h)
    AC_TRY_LINK([#include <sys/types.h>
#include <dirent.h>], [
#ifndef _POSIX_SOURCE
#   ifdef __Lynx__
	 * Generate compilation error to make the test fail:  Lynx headers
	 * are only valid if really in the POSIX environment.
	missing_procedure();
#   endif
#endif
DIR *d;
struct dirent *entryPtr;
char *p;
d = opendir("foobar");
entryPtr = readdir(d);
p = entryPtr->d_name;
closedir(d);
], tcl_ok=yes, tcl_ok=no)
    if test $tcl_ok = no; then
	AC_DEFINE(NO_DIRENT_H)
    fi
    AC_CHECK_HEADER(errno.h, , AC_DEFINE(NO_ERRNO_H))
    AC_CHECK_HEADER(float.h, , AC_DEFINE(NO_FLOAT_H))
    AC_CHECK_HEADER(values.h, , AC_DEFINE(NO_VALUES_H))
    AC_CHECK_HEADER(limits.h, , AC_DEFINE(NO_LIMITS_H))
    AC_CHECK_HEADER(stdlib.h, tcl_ok=1, tcl_ok=0)
    AC_EGREP_HEADER(strtol, stdlib.h, , tcl_ok=0)
    AC_EGREP_HEADER(strtoul, stdlib.h, , tcl_ok=0)
    AC_EGREP_HEADER(strtod, stdlib.h, , tcl_ok=0)
    if test $tcl_ok = 0; then
	AC_DEFINE(NO_STDLIB_H)
    fi
    AC_CHECK_HEADER(string.h, tcl_ok=1, tcl_ok=0)
    AC_EGREP_HEADER(strstr, string.h, , tcl_ok=0)
    AC_EGREP_HEADER(strerror, string.h, , tcl_ok=0)
    # See also memmove check below for a place where NO_STRING_H can be
    # set and why.
	AC_DEFINE(NO_STRING_H)
    fi
    AC_CHECK_HEADER(sys/wait.h, , AC_DEFINE(NO_SYS_WAIT_H))
    AC_CHECK_HEADER(dlfcn.h, , AC_DEFINE(NO_DLFCN_H))
    # OS/390 lacks sys/param.h (and doesn't need it, by chance).
    AC_HAVE_HEADERS(unistd.h sys/param.h)
# SC_PATH_X
#	Locate the X11 header files and the X11 library archive.  Try
#	the ac_path_x macro first, but if it doesn't find the X stuff
#	(e.g. because there's no xmkmf program) then check through
#	a list of possible directories.  Under some conditions the
#	autoconf macro will return an include directory that contains
#	no include files, so double-check its result just to be safe.
# Arguments:
#	none
# Results:
#	Sets the the following vars:
#		XINCLUDES
#		XLIBSW
AC_DEFUN(SC_PATH_X, [
    AC_PATH_X
    not_really_there=""
    if test "$no_x" = ""; then
	if test "$x_includes" = ""; then
	    AC_TRY_CPP([#include <X11/XIntrinsic.h>], , not_really_there="yes")
	else
	    if test ! -r $x_includes/X11/Intrinsic.h; then
	    fi
	fi
    fi
    if test "$no_x" = "yes" -o "$not_really_there" = "yes"; then
	AC_MSG_CHECKING(for X11 header files)
	XINCLUDES="# no special path needed"
	AC_TRY_CPP([#include <X11/Intrinsic.h>], , XINCLUDES="nope")
	if test "$XINCLUDES" = nope; then
	    dirs="/usr/unsupported/include /usr/local/include /usr/X386/include /usr/X11R6/include /usr/X11R5/include /usr/include/X11R5 /usr/include/X11R4 /usr/openwin/include /usr/X11/include /usr/sww/include"
	    for i in $dirs ; do
		if test -r $i/X11/Intrinsic.h; then
		    AC_MSG_RESULT($i)
		    XINCLUDES=" -I$i"
		    break
		fi
	    done
	fi
    else
	if test "$x_includes" != ""; then
	    XINCLUDES=-I$x_includes
	else
	fi
    fi
	AC_MSG_RESULT(couldn't find any!)
	XINCLUDES="# no include files found"
    fi
    if test "$no_x" = yes; then
	AC_MSG_CHECKING(for X11 libraries)
	XLIBSW=nope
	dirs="/usr/unsupported/lib /usr/local/lib /usr/X386/lib /usr/X11R6/lib /usr/X11R5/lib /usr/lib/X11R5 /usr/lib/X11R4 /usr/openwin/lib /usr/X11/lib /usr/sww/X11/lib"
	for i in $dirs ; do
	    if test -r $i/libX11.a -o -r $i/libX11.so -o -r $i/libX11.sl; then
		AC_MSG_RESULT($i)
		XLIBSW="-L$i -lX11"
		x_libraries="$i"
		break
	    fi
	done
    else
	if test "$x_libraries" = ""; then
	    XLIBSW=-lX11
	else
	    XLIBSW="-L$x_libraries -lX11"
	fi
    fi
    if test "$XLIBSW" = nope ; then
	AC_CHECK_LIB(Xwindow, XCreateWindow, XLIBSW=-lXwindow)
    fi
	AC_MSG_RESULT(couldn't find any!  Using -lX11.)
	XLIBSW=-lX11
    fi
# SC_BLOCKING_STYLE
#	The statements below check for systems where POSIX-style
#	non-blocking I/O (O_NONBLOCK) doesn't work or is unimplemented.
#	On these systems (mostly older ones), use the old BSD-style
#	FIONBIO approach instead.
# Arguments:
#	none
# Results:
#		HAVE_SYS_IOCTL_H
#		HAVE_SYS_FILIO_H
#		USE_FIONBIO
#		O_NONBLOCK
AC_DEFUN(SC_BLOCKING_STYLE, [
    AC_CHECK_HEADERS(sys/ioctl.h)
    AC_CHECK_HEADERS(sys/filio.h)
    AC_MSG_CHECKING([FIONBIO vs. O_NONBLOCK for nonblocking I/O])
    else
	    system=unknown
	else
	    fi
	    fi
	fi
    fi
    case $system in
	# There used to be code here to use FIONBIO under AIX.  However, it
	# was reported that FIONBIO doesn't work under AIX 3.2.5.  Since
	# using O_NONBLOCK seems fine under AIX 4.*, I removed the FIONBIO
	# code (JO, 5/31/97).
	OSF*)
	    AC_DEFINE(USE_FIONBIO)
	    AC_MSG_RESULT(FIONBIO)
	SunOS-4*)
	ULTRIX-4.*)
	    AC_MSG_RESULT(O_NONBLOCK)
    esac
# SC_HAVE_VFORK
#	Check to see whether the system provides a vfork kernel call.
#	If not, then use fork instead.  Also, check for a problem with
#	vforks and signals that can cause core dumps if a vforked child
#	resets a signal handler.  If the problem exists, then use fork
#	instead of vfork.
# Arguments:
#	none
# Results:
#		vfork (=fork)
AC_DEFUN(SC_HAVE_VFORK, [
    AC_TYPE_SIGNAL()
    AC_CHECK_FUNC(vfork, tcl_ok=1, tcl_ok=0)
    if test "$tcl_ok" = 1; then
	AC_MSG_CHECKING([vfork/signal bug]);
	AC_TRY_RUN([
#include <stdio.h>
#include <signal.h>
#include <sys/wait.h>
int gotSignal = 0;
sigProc(sig)
    int sig;
    gotSignal = 1;
main()
    int pid, sts;
    (void) signal(SIGCHLD, sigProc);
    pid = vfork();
    if (pid <  0) {
	exit(1);
    } else if (pid == 0) {
	(void) signal(SIGCHLD, SIG_DFL);
	_exit(0);
    } else {
	(void) wait(&sts);
    exit((gotSignal) ? 0 : 1);
}], tcl_ok=1, tcl_ok=0, tcl_ok=0)
	    AC_MSG_RESULT(ok)
	else
	    AC_MSG_RESULT([buggy, using fork instead])
	fi
    fi
    rm -f core
    if test "$tcl_ok" = 0; then
	AC_DEFINE(vfork, fork)
    fi
# SC_TIME_HANLDER
#	Checks how the system deals with time.h, what time structures
#	are used on the system, and what fields the structures have.
# Arguments:
#	none
# Results:
#		USE_DELTA_FOR_TZ
#		HAVE_TM_GMTOFF
#		HAVE_TM_TZADJ
#		HAVE_TIMEZONE_VAR
AC_DEFUN(SC_TIME_HANDLER, [
    AC_CHECK_HEADERS(sys/time.h)
    AC_HEADER_TIME
    AC_STRUCT_TIMEZONE
    AC_MSG_CHECKING([tm_tzadj in struct tm])
    AC_TRY_COMPILE([#include <time.h>], [struct tm tm; tm.tm_tzadj;],
	    [AC_DEFINE(HAVE_TM_TZADJ)
	    AC_MSG_RESULT(yes)],
	    AC_MSG_RESULT(no))
    AC_MSG_CHECKING([tm_gmtoff in struct tm])
    AC_TRY_COMPILE([#include <time.h>], [struct tm tm; tm.tm_gmtoff;],
	    [AC_DEFINE(HAVE_TM_GMTOFF)
	    AC_MSG_RESULT(no))
    # Its important to include time.h in this check, as some systems
    # (like convex) have timezone functions, etc.
    have_timezone=no
    AC_MSG_CHECKING([long timezone variable])
	    [extern long timezone;
	    timezone += 1;
	    exit (0);],
	    [have_timezone=yes
	    AC_DEFINE(HAVE_TIMEZONE_VAR)
	    AC_MSG_RESULT(no))
    # On some systems (eg IRIX 6.2), timezone is a time_t and not a long.
    if test "$have_timezone" = no; then
    AC_MSG_CHECKING([time_t timezone variable])
	    [extern time_t timezone;
	    timezone += 1;
	    exit (0);],
	    [AC_DEFINE(HAVE_TIMEZONE_VAR)
	    AC_MSG_RESULT(no))
    fi
    # AIX does not have a timezone field in struct tm. When the AIX bsd
    # library is used, the timezone global and the gettimeofday methods are
    # to be avoided for timezone deduction instead, we deduce the timezone
    # by comparing the localtime result on a known GMT value.
	AC_CHECK_LIB(bsd, gettimeofday, libbsd=yes)
	if test $libbsd = yes; then
	    AC_DEFINE(USE_DELTA_FOR_TZ)
	fi
    fi
# SC_BUGGY_STRTOD
#	Under Solaris 2.4, strtod returns the wrong value for the
#	terminating character under some conditions.  Check for this
#	and if the problem exists use a substitute procedure
#	"fixstrtod" (provided by Tcl) that corrects the error.
# Arguments:
#	none
# Results:
#	Might defines some of the following vars:
#		strtod (=fixstrtod)
AC_DEFUN(SC_BUGGY_STRTOD, [
    AC_CHECK_FUNC(strtod, tk_strtod=1, tk_strtod=0)
    if test "$tk_strtod" = 1; then
	AC_MSG_CHECKING([for Solaris 2.4 strtod bug])
	AC_TRY_RUN([
	    extern double strtod();
	    int main()
		char *string = "NaN";
		char *term;
		strtod(string, &term);
		if ((term != string) && (term[-1] == 0)) {
		    exit(1);
		exit(0);
	    }], tk_ok=1, tk_ok=0, tk_ok=0)
	if test "$tk_ok" = 1; then
	    AC_MSG_RESULT(ok)
	else
	    AC_MSG_RESULT(buggy)
	    AC_DEFINE(strtod, fixstrtod)
	fi
    fi
# SC_TCL_LINK_LIBS
#	Search for the libraries needed to link the Tcl shell.
#	Things like the math library (-lm) and socket stuff (-lsocket vs.
#	-lnsl) are dealt with here.
# Arguments:
#	Requires the following vars to be set in the Makefile:
#		DL_LIBS
#		LIBS
#		MATH_LIBS
# Results:
#	Subst's the following var:
#		TCL_LIBS
#		MATH_LIBS
#	Might append to the following vars:
#		LIBS
#	Might define the following vars:
#		HAVE_NET_ERRNO_H
AC_DEFUN(SC_TCL_LINK_LIBS, [
    # On a few very rare systems, all of the libm.a stuff is
    # already in libc.a.  Set compiler flags accordingly.
    # Also, Linux requires the "ieee" library for math to work
    # right (and it must appear before "-lm").
    AC_CHECK_FUNC(sin, MATH_LIBS="", MATH_LIBS="-lm")
    AC_CHECK_LIB(ieee, main, [MATH_LIBS="-lieee $MATH_LIBS"])
    # On AIX systems, libbsd.a has to be linked in to support
    # non-blocking file IO.  This library has to be linked in after
    # the MATH_LIBS or it breaks the pow() function.  The way to
    # insure proper sequencing, is to add it to the tail of MATH_LIBS.
    # This library also supplies gettimeofday.
    libbsd=no
	    MATH_LIBS="$MATH_LIBS -lbsd"
	fi
    fi
    # Interactive UNIX requires -linet instead of -lsocket, plus it
    # needs net/errno.h to define the socket-related error codes.
    AC_CHECK_LIB(inet, main, [LIBS="$LIBS -linet"])
    AC_CHECK_HEADER(net/errno.h, AC_DEFINE(HAVE_NET_ERRNO_H))
    #	Check for the existence of the -lsocket and -lnsl libraries.
    #	The order here is important, so that they end up in the right
    #	order in the command line generated by make.  Here are some
    #	special considerations:
    #	1. Use "connect" and "accept" to check for -lsocket, and
    #	   "gethostbyname" to check for -lnsl.
    #	2. Use each function name only once:  can't redo a check because
    #	   autoconf caches the results of the last check and won't redo it.
    #	3. Use -lnsl and -lsocket only if they supply procedures that
    #	   aren't already present in the normal libraries.  This is because
    #	   IRIX 5.2 has libraries, but they aren't needed and they're
    #	   bogus:  they goof up name resolution if used.
    #	4. On some SVR4 systems, can't use -lsocket without -lnsl too.
    #	   To get around this problem, check for both libraries together
    #	   if -lsocket doesn't work by itself.
    tcl_checkBoth=0
    AC_CHECK_FUNC(connect, tcl_checkSocket=0, tcl_checkSocket=1)
    if test "$tcl_checkSocket" = 1; then
	AC_CHECK_LIB(socket, main, LIBS="$LIBS -lsocket", tcl_checkBoth=1)
    fi
    if test "$tcl_checkBoth" = 1; then
	tk_oldLibs=$LIBS
	LIBS="$LIBS -lsocket -lnsl"
	AC_CHECK_FUNC(accept, tcl_checkNsl=0, [LIBS=$tk_oldLibs])
    fi
    AC_CHECK_FUNC(gethostbyname, , AC_CHECK_LIB(nsl, main,
	    [LIBS="$LIBS -lnsl"]))
    # Don't perform the eval of the libraries here because DL_LIBS
    # won't be set until we call SC_CONFIG_CFLAGS
    TCL_LIBS='${DL_LIBS} ${LIBS} ${MATH_LIBS}'
    AC_SUBST(TCL_LIBS)
    AC_SUBST(MATH_LIBS)
