[GRASS5] Silly Gdal Lib Error [off]
Jeshua Lacock jeshua at SierraMaps.com
Sun May 27 14:37:00 EDT 2001
On Sunday, May 27, 2001, at 10:58 AM, Glynn Clements wrote:
>> ranlib /usr/src/gdal-1.1.4/gdal.a
>> ranlib: file: /usr/src/gdal-1.1.4/gdal.a(pnggccrd.o) has no symbols
>> ranlib: file: /usr/src/gdal-1.1.4/gdal.a(pngvcrd.o) has no symbols
>> ranlib: file: /usr/src/gdal-1.1.4/gdal.a(tif_pixarlog.o) has no symbols
> For each of the three corresponding source files, the entire file is
> enclosed in a #if[def]/#endif. The result will be an object file with
> no symbols. It would appear that your version of ranlib doesn't like
> this (i.e. it fails to update the index, rather than just ignoring the
> files).
> Try manually removing the above files from the archive, with
> 	ar d gdal.a pnggccrd.o pngvcrd.o tif_pixarlog.o
> Then re-run ranlib.
Hello,
Thanks for your suggestions Glynn, despite your excellent help, I am
still getting the same make errors.
I no longer get the ranlib "has no symbol" after running ar.
I guess I will email Frank...
Thanks again,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
