[GRASS5] which tag?
Markus Neteler neteler at geog.uni-hannover.de
Wed May 30 11:34:35 EDT 2001
On Wed, May 30, 2001 at 04:57:12PM +0200, Andreas Lange wrote:
> Hi Markus,
> thanks for the nice diagram. I am aware of the structure.
> But how do i update my source directory, which i checked out with the
> pre1 tag?
> Do i have to use cvs update -r releasebranch_11_april_2001_5_0_0 and
> then cvs up -dP ?
> This is how it is described on the grasscvs.html page.
> Sorry for my ignorance,
Hi Andreas,
sorry for my bad explanations... I guess a
cvs up -dPA should help
to remove the sticky tag.
I would welcome hints to improve the grasscvs.html page (preferably text
pieces to insert)!
Regards
 Markus
> Markus Neteler wrote:
> > On Wed, May 30, 2001 at 04:12:03PM +0200, Andreas Lange wrote:
> > > Hi,
> > > one short question:
> > > I checked out the release_grass500pre1_20_may_2001 version for testing.
> > > If i update now with cvs update -dP nothing is updated.
> > > Do i have to switch back to the release branch
> > > releasebranch_11_april_2001_5_0_0 to get the new code?
> > > I am a bit confused right now. The grasscvs page does not help too.
> > Hi Andreas,
> > please note that we have
> >  tags
> > --+----+------------> exp (main)  (currently unused)
> >           \         +tag: release_grass500pre1_20_may_2001
> >            +--------|--------------+-------> releasebranch_11_april_2001_5_0_0
> >                                   today
> > You see that you may not mix tags on release_branch and the branch itself.
> > Does this clear the situation?
> > Regards
> >   Markus
> > grass5 mailing list
> > grass5 at geog.uni-hannover.de
> > http://www.geog.uni-hannover.de/mailman/listinfo/grass5
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
Markus Neteler *  University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494  Fax: -3984
