[GRASS5] new Linux Binaries
Glynn Clements
glynn.clements at virgin.net
Thu May 31 03:41:00 EDT 2001
Markus Neteler wrote:
> > > On Wed, May 30, 2001 at 03:19:28PM +0200, mlennert at ulb.ac.be wrote:
> > > > Markus,
> > > > Can I recreate the Linux binaries with the May 20 snapshot, or
> > > > should I use a new snapshot with the latest changes ?
> > > Personally I would prefer the latest code (due to new Xdriver
> > > improvements). However, this would be 5.0.0pre1b. Or shall I re-tag
> > > and we produce 5.0.0pre2 ?
> > If we are going to produce another release then it should be named
> > 5.0.0pre2. I see no reason for using multiple versions of pre1.
> O.k. (good luck that pre1 is not anounced yet :-)
> Perhaps we should wait until the V_stuff is fixed? Glynn, Huidae, do
> you have a timeline for this?
I've commited the initial changes (remove ASIAN_CHARS macro; the 7-bit
wrapping has gone altogether).
I'll do the more substantial changes to vasklib today or tonight.
Glynn Clements <glynn.clements at virgin.net>
