[GRASS5] Re: Terminal Errors
Jeshua Lacock jeshua at SierraMaps.com
Thu May 17 19:46:07 EDT 2001
On: Mon, 19 Feb 2001, John Huddleston wrote:
> Subject: Re: [GRASS5] vt100 error with osx + xterm error
> Justin,
> I get that same message using Cygwin.   I checked the
> /usr/lib/terminfo and all is well there.  I'll look at the
> initscr
> John Huddleston
> Well, I fixed the error for Cygwin.  It turned out that the
> /usr/lib/terminfo directory was a symbolic link to the
> ./share/terminfo directory.   I removed the symbolic
> link, moved the share terminfo directory to /usr/lib and
> created a symbolic link from share to ../lib for the
> terminfo directory.   No more error message.  That's
> a weird one.   It might be because I am using the X-win32
> server from StarNET.  Programs compiled outside of
> Cygwin do not recognize the Cygwin symbolic links.  The
> xfree binary should work OK.
> John Huddleston
I just looked, and I do not have a /usr/lib/terminfo, in fact there is
not a terminfo anywhere on my system.   Could that be the problem?  How
might I create such a file?
Thanks,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
