[GRASS5] nothing to do with r.reclass
Glynn Clements glynn.clements at virgin.net
Thu May 17 18:07:49 EDT 2001
Jeshua Lacock wrote:
> I was trying out the GUI a bit and if I choose Create New Location in
> the GRASS opening dialog, the program crashes (maybe). At least, it
> disappears.
> Here is the message when the program seems to disappear:
> Error opening terminal: xterm.
> Any ideas?
The curses library can't find the terminfo/termcap entry for "xterm".
This seems to be a common problem on MacOS X. I don't know what the
solution is. Andy Agena <andya at mac.com> was having exactly the same
problem. Andy: did you ever manage to solve it?
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
