[GRASS5] Multiple attribute support in GRASS5.1:someconsiderations (long)
Andrea Aime aaime at comune.modena.it
Mon May 14 09:17:33 EDT 2001
Frank Warmerdam wrote:
> Radim Blazek wrote:
> > SQLite seems to be a good solution. The only problem I see is that there is no
> > GUI front-end which was one of my criteria. Dbf files may be edited in StarOffice
> > and MSAccess (including forms). I thing that we don't have human resources for developing
> > database front-end within grass and we don't want to reinvent wheel. So if such front-end
> > is available is important.
> Radim,
> It seems to me that if we use easily substitutable SQL based RDBMS systems
> then folks that need forms support and a GUI front end can choose an
> RDBMS that has them.  If we use DBF and depend on external gui front ends it
> still won't be possible to distribute GRASS database forms applications since
> different users might choose different target RDBMSes, right?
> Is the GUI front end and forms requirement just so that users can see their
> data interactively, or so that substantial forms based applications can be
> built?
> Someone mentioned the issue of having different programs for different
> databases.  I completely agree that if we integrate SQL support smoothly
> into GRASS that the applications should be insulated from the actual database
> backend by some sort of plugable library.  This might be based on an existing
> standard like ODBC or just a custom simplied database API.  I was impressed
> with the relative simplicity of the abstracted database interface in Python.
> BTW, does Postgres have a nice gui front end?  I have always done my work from
> psql, but I would dearly love to try something a little more visual. :-)
Depending on your client you can choose among:
* pgAccess, tcl/tk interface for Unix desktop;
* pgAdmin, Visual Basic interface for Windows users;
* phpPgAdmin (or something like this...), a web interface
.. need more?
> > BTW: SQLLite files are not portable (The key size thus depends on the size of
> > an integer on the host computer.) but that doesn't matter.
> This is annoying.  In the short term I guess it would be necessary to do a
> database dump and reload to transport to different system types.  I would
> ideally like to see some sort of automatic translation be done at lower
> performance at some point.
Uhm, I don't see it as a major problem, v.out.ascii can dump the table
along with the coordinates, and v.in.ascii do the opposite.
Regards
Andrea Aime
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
