[GRASS5] Driver Update
Markus Neteler neteler at geog.uni-hannover.de
Tue May 8 07:44:36 EDT 2001
> > > if you allow, an offlist query: Is it possible to implement an auto-redraw
> > > into the monitor if the user resizes it? Somehow like d.zoom does the
> > > redraw? The would be *really* great if it wouldn't destabilize the driver.
> > AFAICT, d.zoom uses the list constructed by D_add_to_list() to perform
> > the redraw. I haven't looked into how this mechanism works enough to
> > be able to determine how involved this would be.
> OK; I've just committed some changes which will implement this.
> Resize events are no longer processed while a client is connected;
> instead, a flag is set, and the resize is handled once the driver is
> idle.
> This needs testing thoroughly; XDRIVER will now spawn whatever
> commands are added to the list via D_add_to_list(). If any of these
> commands don't like being run in this environment, problems may occur;
> in which case, the commands will need to be fixed, or at least have
> the D_add_to_list() call removed.
Glynn,
that's great!! I have just tested, it seems to run well.
This has been a long awaited feature of XDRIVER...
Thanks a lot,
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
