[GRASS5] [bug #243] (grass) i.ortho.photo: second control point set, but not displayed
Glynn Clements glynn.clements at virgin.net
Thu May 3 00:34:20 EDT 2001
Markus Neteler wrote:
> > > Subject: i.ortho.photo: second control point set, but not displayed
> > > i.ortho.photo
> > >  - if second control point is set by mouse, it is not indicated
> > >    immediately in orange color (right window) [was o.k. in GRASS 4.x]
> > Which bit? i.ortho.photo is just a menu for the various photo.*
> > programs.
> Sorry. It appears in
> 7.     Compute ortho-rectification parameters
> you have the unrectified aerial image to the left and the raster
> reference to the right. When clicking a ground control point (GCP)
> in the left, you get a small colored circle in place, when clicking
> into the reference image to the right, this small colored circle
> doesn't appear (immediately). In i.points that's o.k.
> It appears *after* accepting the button (left mouse button), however,
> it should appear immediately with orange color and change to green
> if accepted with left mouse button.
I've added an R_stabilize() call in what appears to be the appropriate
place; can you check that this fixes the problem?
BTW: I did post a reply via the RT, but I haven't seen it appear on
the list.
Glynn Clements <glynn.clements at virgin.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
