[GRASS5] [bug #242] (grass) R_polygon_abs() seems to ignoreislands
Justin Hickey jhickey at hpcc.nectec.or.th
Wed May 2 23:39:37 EDT 2001
Hi Eric and Glynn
Glynn Clements wrote:
> Eric G. Miller wrote:
> > We're only talking the context of filling
> > an area defined by a polygon, but allowing a portion of the filled
> > area to be masked (so it retains whatever was already there).
> > Like:
> >   \xxxxx\___________
> >    |xxxxxxxxxxxxxxxx|
> >    \x-------xxxxxxx/
> >     \x\     \xxxxx/
> >      \x\_____\xxx/
> >       \xxxxxxxxx/
> OK; a lot of people (myself included) wouldn't call that a "polygon".
> Further, a lot of people automatically read "polygon" as "convex
> polygon", as many graphics APIs are limited to such.
> A correct solution is far from straightforward, as the Mesa[1] folks
> have discovered.
I find this strange since there exists a well known graphics polygon
filling algorithm that can handle polygons which are concave, convex,
self-intersecting, and polygons with holes. Eric and I briefly discussed
this in a previous thread. I will include part of it (two sections) for
Glynn's benefit.
Justin Hickey wrote
> > I'm sorry I didn't read my mail this weekend, but the most
> > efficinet way to solve your problem is to use a computer graphics
> > algorithm for filling polygons. This algorithm handles convex
> > polygons, concave polygons, self-intersecting polygons, and
> > polygons with holes (or islands in your case). Since you already
> > did a lot of coding, you may not be interested in this algorithm.
> > However, if you are interested, it can be found in the book
> > "Computer Graphics: Principles and Practice" by Foley, Van Dam,
> > Feiner, and Hughes (see section 3.6 "Filling Polygons"). If you
> > cannot find this book, let me know and I'll see what I can do to
> > summarize the algorithm for you. Note that with this algorithm, you
> > do not have to worry about which areas are islands. However, you
> > may need to modify this if you have nested islands.
Eric Miller wrote
> Such changes would have to be made at the driver lib side, as Radim
> noted.  I don't know if I'm up to adding in another protocol call
> to the rasterlib and the various driver libs.  It'd probably be the
> "correct" way to handle these islands, but there are many places
> where changes would have to be made (as opposed to one place in the
> calling module).
So, as Eric said, this algorithm may mean a lot of work to implement but
I agree with him that it is the correct solution.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
