[GRASS5] [bug #247] (grass) nviz2.2: the parameter el= is inconsistent
Request Tracker grass-bugs at intevation.de
Wed May 2 07:39:25 EDT 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=247
Subject: nviz2.2: the parameter el= is inconsistent
the parameter el= is inconsistent (e= should be allowed as well),
   parameter order should be free (use a "case" switch?)
-------------------------------------------- Managed by Request Tracker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
