[GRASS5] Driver Update
Justin Hickey jhickey at hpcc.nectec.or.th
Wed May 2 00:43:24 EDT 2001
Hi Glynn
Glynn Clements wrote:
> I've commited an update to
> src/display/devices/lib/command.c which checks the return value from
> the write() call, in case that's failing for some reason.
Now that I could compile again, I tried d.mon and it seems that there is
no change in the output. That is, the write() call doesn't seem to be
failing. Here's the output.
GRASS 5.0.0pre1 > d.mon start=x0
using default visual which is TrueColor
Visual is read-only or using a private colormap
ncolors: 32768
allocating memory...
About to call prepare_connection_sock
About to call get_connection_sock
Graphics driver [x0] started
About to call Do-work (0)
About to call Do-work (1)
Monitor: _send: write was successful
    <Above message printed a total of 43 times>
Warning - no response from graphics monitor <x0>.
Check to see if the mouse is still active.
ERROR - no response from graphics monitor <x0>.
Monitor: read1: n_read = 0
get_command was != 0
About to call close(_wfd)
Problem selecting x0. Will try once more
Mapset <PERMANENT> in Location <spearfish>
GRASS 5.0.0pre1 > About to call Do-work (0)
I'm not sure if knowing that write was called 43 times is significant or
not, but a little more knowledge now.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
