[GRASS5] [bug #824] (grass) d.3d tcltkgrass interface : wrong zero elevation option
Glynn Clements glynn.clements at virgin.net
Thu Nov 8 11:32:44 EST 2001
Helena Mitasova wrote:
> Should d.3d be put into attic? I found that people often mistake it for
> nviz and expect it to work like that and they are very disappointed. This is a very old
> program which has not been
> worked on since we had SG3d (which may be 10 years) and if you try it
> it is really difficult to work with and nviz now should work on every machine (at least
> I hope)?
d.3d can be run non-interactively; AFAIK, nviz can't.
Glynn Clements <glynn.clements at virgin.net>
