[GRASS5] r.rescale range question
Andreas Lange Andreas.Lange at Rhein-Main.de
Fri Nov 9 10:43:29 EST 2001
Markus Neteler schrieb:
> On Fri, Nov 09, 2001 at 02:39:36PM +0000, Glynn Clements wrote:
> > Markus Neteler wrote:
> > > while looking at r.rescale I found
> > >  r.rescale [-q] input=name [from=min,max] output=name [to=min,max]
> > >    [title="phrase"]
> > >       to   The output data range
> > >            default: 1,255
> > > This range looks a bit unusual. Shouldn't it be 8bit = 0..255?
> > I would guess that it's a leftover from when zero was null.
> > Personally, I would suggest just making the "to" option mandatory. I
> > can't see why 255 is any more suitable as a default than any other
> > value.
> Thanks for all suggestions. I have updated module and html page
But that is only true if we do not implement the -z flag which changes
to zero (0) for null values.
Please look in the RT and my other mails on the problems with r.reclass.
I am lost with the problem in r.reclass somehow. Would appreciate any
help with that.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
